Move procuct description right of image/right part
10 years 3 months ago #247907
by lousyfool
Replied by lousyfool on topic Move procuct description right of image/right part
@geogeo:
That's because you're not using the "Default" layout on product pages... at least not on the one you linked to. You're using the "Tabular" layout instead.
Try switching to Default instead: www.hikashop.com/support/documentation/5...tml#display_products
10 years 3 months ago #247933
by geogeo
Replied by geogeo on topic Move procuct description right of image/right part
i did it, nothing changed too
10 years 3 months ago #247936
by lousyfool
Then you must have done something wrong, like e.g. editing the show_default view for the wrong template or so.
Please check per FTP if you have the file /templates/jsn_glamo_free/html/com_hikashop/product/show_default.php
If yes, please check if it contains the changes you've made.
If not, you have edited the wrong file, or the right file for the wrong template or something.
10 years 3 months ago #247978
by Jerome
Replied by Jerome on topic Move procuct description right of image/right part
The product layout is loaded by the view "product / show".
The variable $this->productlayout is initialized in the view.html.php from the product settings and the HikaShop configuration.
Because it is possible to override the product layout per product and per category.
$this->setLayout($this->productlayout);
echo $this->loadTemplate();
10 years 3 months ago #247979
by lousyfool
Thanks Jerome,
Good hint, but @geogeo has managed to switch the layout from "Tabular" (which it was when he posted here ) to "Default" on this product page .
So, there's no problem with switching layouts, but apparently "only" with a customization supposedly made in "show_default" not showing.
10 years 3 months ago #247998
by geogeo
It works!!!You are completely right!! I didnt notice that i was working on the wrong template. Many many thanks!!
