Fix breadcrumb in products
13 years 4 months ago #112726
by Zoller85
Fix breadcrumb in products was created by Zoller85
Hello again ^^
I know there is some similar posts... but i did not find the right answer for my particular problem
In the HikaShop the breadcrumb is randomly show the category names
When there are also sub-categories, icannot see them /check screenshot i attached/. But i have one morep roblem. there is an arrow, so i can navigate to the next item in the same category... but i don't want it and i did not checked aníthing similar function to yes in the admin area
Can u give me some advice? Clearing the cache, deleting and adding again categories not seems to work.
There should be the breadcrumb like this:
Home > Webshop > Poik > Scube Poi
Z.
Z.
13 years 4 months ago #113058
Replied by nicolas on topic Fix breadcrumb in products
1. You probably need to turn off the "simplified breadcrumb" option of the configuration.
2. You need to turn off the option "Show shortcuts to other category products" of the configuration for that.
The following user(s) said Thank You: Zoller85
13 years 4 months ago #113098
by Zoller85
Replied by Zoller85 on topic Fix breadcrumb in products
Thanks for the help ^^ I also had to disable the System Cache in
Joomla, and now it's perfect ^^ Just one more question... i did not find any but, is there some sort of function, or button or hyperlink to navigate back, and not mean the breadcrumb now
Z.
Z.
13 years 4 months ago #113151
There is the back button of your browser of course.
Now if you want to add a back button on top of that on the product page, you can follow this:
www.hikashop.com/en/forum/4-how-to/38337...duct-page.html#38437
