- Thank you received: 20
Cursor filter for range between 2 custom field values
9 years 9 months ago #261661
by dyvel
Cursor filter for range between 2 custom field values was created by dyvel
I would like to make a filter, where the user can filter using the cursor and set a single value, and filter based on 2 custom fields that contains low and high value.
E.g. room size. A product could be ideal for a given room size, e.g. between 50 - 95 m2.
I have such 2 custom fields on the product.
I would like to have a cursor, that I could set to e.g. 75 and only display the products where 75 is within the range of my low and high fields. Makes sense?
Is this possible in any way?
Another thing - cursor number seems buggy - no matter if I set it to 1, 2, 3 or 4, it always displays 2
9 years 9 months ago - 9 years 9 months ago #261668
by Philip
Replied by Philip on topic Cursor filter for range between 2 custom field values
Theoretically what you ask for, is possible with Business version, you can have a look on this tutorial to learn more details about this subject.
Last edit: 9 years 9 months ago by Philip.
