Shadowbox doesn't work correctly
11 years 10 months ago #182377 by MatteoLin
-- Joomla version -- : 3.3.6
In my site, i have a problem with variants's images that I suppose is related with Shadowbox.
When I began using hikashop, version 2.2.2, I had installed shadowbox as alternative popup mode, following the instructions as provided by you. In an OLD version of these instructions, you suggest to modify some code to avoid to show duplicate images when only the main product has an image and variants use the same. So I did.
I don't remember the name of the file that I've modified.
Now, I have a product whose variants has its own image. But I can see only the image related to main product!
Moreover, shadowbo doesn't show the title.
Could you help me to solve this problem?
Thank you
11 years 10 months ago #182397 by Mohamed Thelji
To use shadow box you'll just have to follow that tutorial : www.hikashop.com/support/documentation/1...ox-media-player.html
Also, regarding your issue can you give us more information through some screenshots for example ?
