Order status is not changing to "cancelled"
9 years 1 month ago - 9 years 1 month ago #279260 by joshualdouglas
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.5.38
I have noticed a bug in one of my Hikashop sites. The order status is not changing to "cancelled" when clicking "cancel and return to seller" in the Paypal redirect. The order status remains "Created". This does not happen in my other Hikashop sites.
In the paypal method specific configuration I have:
Invalid status: cancelled
Pending status: pending
Verified status: Confirmed
What could I have done wrong in this site?
Last edit: 9 years 1 month ago by joshualdouglas.
9 years 1 month ago #279262 by nicolas
The order status changes to the first ( in time, not in the rows of the listing) status you enabled in the column "cancelled" of the System>Order statuses menu.
9 years 1 month ago #279322 by joshualdouglas
The first enabled column is "cancelled" - please see attached.
Is there something else?
Thank you,
J.
9 years 1 month ago #279330 by nicolas
Please deactivate all the statuses in that column. Then, activate "cancelled" first and then "refunded" to make sure that it is the first.
Also, make sure that the "created" status is activated in the "cancellable" column so as to authorize the customer to cancel orders with the "created" order status. Otherwise, it won't do the change.
9 years 1 month ago #279457 by joshualdouglas
I have just tried this. The order status still remains "cancelled".
Thanks,
J.
9 years 1 month ago #279802 by joshualdouglas
Do I need to edit some code?
Thanks,
Josh.
9 years 1 month ago #279813 by nicolas
In a previous message you said that the order status is cancelled:
www.hikashop.com/forum/orders-management...ancelled.html#279457
So we thought that the problem was solved.
If you still have a problem, can you provide again a screenshot of the Order statuses listing now that you've modified them ?
9 years 1 month ago #279874 by joshualdouglas
Apologies, I meant to say "The order status still remains "created".
Please see attached images.
Thanks,
Josh.
9 years 1 month ago #279918 by Mohamed Thelji
Hello Josh,
We just tested it on our end and it worked fine, can you give us a link to your website so that we can directly reproduce your issue ?
Thank you.
