General Question
14 years 6 months ago #49982 by cvnet
Replied by cvnet on topic Re: General Question
it worked, thanks a bunch for all your help
14 years 6 months ago #51373 by cvnet
Hi Guys
I really need help fast, our site is live and the serials are not getting assigned to orders, please advise
14 years 6 months ago #51385 by Jerome
Replied by Jerome on topic Re: General Question
Access you gave me last time did not work any more so I can't check your configuration etc.
Did you change something when you went to production ?
Did the server, database change ?
14 years 6 months ago #51480 by cvnet
I pm'ed u just now, yes it did work fine, then I had to remove the test products and install actual products, and yesterday the site went live and we have orders which have no serial assign to them.
Under the product page it shows we got 100 item available but I have no idea why it is not assigning them.
Please do tell me exactly what you do, so next time I dont have to bug you guys.
Thanks in advance
14 years 6 months ago #51481 by Jerome
Last time I recreate the link between the product and the pack.
I think I have create a new serial too and look if the product quantity changed.
You can use the "refresh association" button in the order to make associations and look at the product quantity too (in the front end).
I will make new tests in order to reproduce your problem.
Best regards,
14 years 6 months ago #51482 by cvnet
we have customers on our back, if you could resolve this sooner it would be much appreciated.
14 years 6 months ago #51484 by cvnet
can u please use the current packs and serials to solve the problem? because orders are conf, but no pin assigned.
14 years 6 months ago #51485 by cvnet
I pm'ed u the new user/pass on the forum.
No i did not change anything, I just deleted the old pack and installed a new ones, and created a product and link it to the pack.
I do not see "refresh association" anywhere.
14 years 6 months ago #51486 by cvnet
found the refresh association button and it works once I click on it, i processed all but one order using that method.
Now order S16 is still has no pins assigned, last time once you did your thing, it also assigned pins to confirmed orders, So i want to keep that order like that to make sure our system is working, once u r done.
14 years 6 months ago #51487 by cvnet
I pm'ed you the user/pass again on the forum, please have a look at it.
14 years 6 months ago #51492 by Jerome
Sorry for the delay, I did't have any alert on private messages.
I have upgrade your store with the latest version of HikaSerial, this new version have a fix for paypal notifications and add some features.
It should work fine with the paypal patch !
14 years 6 months ago #51498 by cvnet
I have send u the pm twice
14 years 6 months ago #51499 by cvnet
just pm'ed u again
If i upgrade, will I lose current serials and orders?
14 years 6 months ago #51506 by Jerome
Updates does not affect your serials, your packs, or your assignations.
But like I said, I have finally see your PM, I went to your website and update your HikaSerial with the latest version which is not published yet (the 1.2.0)
So you have now the latest version installed in your website. The 1.2.0 version of HikaSerial should be published (and so accessible for download) during the week end of begin of next week.
14 years 5 months ago #51536 by cvnet
I see that I do have hikaserial 1.2.0 and it is published, and I also see GroupAssociation - HikaSerial Consumer plugin which is not published, should i publish this?
There still order that has no key assign to it (Order number S16)
What do I do?
14 years 5 months ago #51540 by Jerome
If an order does not change, HikaSerial can't see if there is some serials to assign/unassign.
When an order change is status, when the order change to "confirmed" or change to "cancel", HikaSerial is triggered and would modify the serial assignations.
There is two ways to refresh an order :
- Use the "refresh association" button.
- Change the status of the order twice (first to "created" for example and after to "confirmed")
You can activate the "Group Association" plugin but if you don't want to use such feature you can let it unpublished :)
The following user(s) said Thank You: cvnet
14 years 5 months ago #51541 by cvnet
thanks a bunch, I changed it to created then again to confirmed and it assigned.
Can you please tell me why it did not do it in the first place? I need to know that for future products.
Thanks all your help
14 years 5 months ago #51631 by Jerome
It was just a problem with the paypal notification which has been fixed in HikaSerial 1.1.0-1
So this particular problem will not append.
After that, if you made some modifications in an order and the status does not change, use the "refresh association" button in the backend to manually check assignations.
14 years 5 months ago #51693 by cvnet
Jerome today there was a new order "B2A3" and it did not assign pin number to it, the order was confirmed, I had to manually press the "Refresh associations" to have it assign pin number, we need this to be fixed since the site is live now, please have a look and advise.
14 years 5 months ago #51694 by Jerome
Your error is very strange. Can you send a FTP access I have to check if your files are up to date and check your PHP log.
The assignation works well if you change the order status in the backend or if you use the button.
It's like the HikaSerial trigger is not called by HikaShop.
I have to make some tests and simulate a transaction (with a fake paypal notification).
Jerome
Time to create page: 0.123 seconds
