- Thank you received: 10
How to display related products in product page
In order to be more clear have a please look on my screenshot :
This step is to create the link between your product, and other products (The Related products)
Second step, for display your related products on your product page you must create a related module.
In Extensions => Modules, then click "new", and config your module with your needed settings.
You will see more information in this tutorial .
Then, from your Main HikaShop Configuration (Components => HikaShop => Configuration), then Display tab and Product options part
Here, you must add your Related Module Products in order to add the module in your product page.
1. Bundle products is to update the quantity of other products when that product is bought.
2. You should be able to do that by adding CSS.
For example:
Well, I'm not sure. I would need a link to that page to be able to directly check the CSS there.
Could you provide that ?
that's because even with your "!important" the priority of your selector was not high enough, for be sure that your custom command css override others commands, the point is to increase selector priority, see my example :
Now :
.hikashop_img_pane_panel{
color: red !important;
After : Higher priority
.hikashop_img_pane_panel a {
Higher priority Level up
span.hikashop_product_name .hikashop_img_pane_panel a {
See this documentation from w3school.com to learn more about this.
Several points in order to be able to help you on this new subject :
1. I'm sorry for this but can you provide your settings screenshot in English ?
2. We will need to process some tests directly on your website, can you provide Url link and frontend/backend access via our Contact us form
Note : When you provide references use the Contact us form AND don't forget to add Url link to this topic
Awaiting news from you to progress on your subject.
Sorry for this return but we process some test directly on your website via your Url link and test it on Chrome and Opera and it works as expected.
So, in order to progress, do you have any new details that can help us like a step by step process to reproduce the issue, did you process your test while being logged by example, or any elements I forget that can be related to your problem.
Unfortunately if we are able to see your issue, solve it will be really difficult.
Sorry to say that, but that way we won't be able to help you, I mean in order to help you we need these criteria :
- First have a view of your screenshot OR video in English, and explanations to understand what you want achieved.
- And especially please do not multiply the different problem in the same topic, thank you.
You have to create, like we previously do, a topic per issue, so create a new one for this new issue.
Thanks for your understanding.
