Error: No Shipping method found for Canada Post
9 years 3 months ago - 9 years 3 months ago #275144 by Jerome
I'm sorry but our answer are still the same.
You should contact the Canada Post support in order to get more information about your credentials.
Please note that the Canada Post plugin in HikaShop is using the old Canada Post API and not the new REST API one (which requires another plugin than the one in the HikaShop packages) ; that could be an important information to gave to their support.
Canada Post deprecated their old API and you need to be sure, really really sure, that your account is valid for the old API.
If not, it means that you're in the new API and it requires, as I previously told you, another plugin.
www.hikashop.com/component/hikashop/prod...-canadapost-adv.html
Last edit: 9 years 3 months ago by Mohamed Thelji.
9 years 3 months ago #275207 by peterACI
Well thanks for finally at least sending me the link to the other plugin.
I already told you that I have contacted Canada Post numerous times and I have the correct credentials needed for this plugin so it's completely useless for you to even mention contacting them again. Obviously there is a flaw in your extension that you may want to consider looking at seeing as how there are many other people that have asked for help on the topic to no avail.
9 years 3 months ago #275208 by peterACI
It's actually ridiculous that the only solution to this basic problem is to buy a $127 plugin. What a money grab!
9 years 3 months ago - 9 years 3 months ago #275216 by Mohamed Thelji
As you can see on the screenshot that Jérome sent you : pasteboard.co/GCVxGN0.png
The Canada Post shipping platform is returning the error message "Merchant CPC ID not found on server.", which means that you either didn't properly set your Canada Post Merchant ID through the "Merchant id" option of your Canada Post shipping configuration page, or that your Merchant ID isn't compatible with their old API.
The price of the "Canada Post (Advanced)" shipping plugin is actually 45 €.
Also, we can't really help if their platform is only returning the "Merchant CPC ID not found on server." error message with your merchant ID, when we test it on our end with a valid Merchant ID, it's working fine.
