Shipping Method Not Showing
11 years 6 months ago #198792
by buffdownunder
Edward
Replied by buffdownunder on topic Re: Shipping Method Not Showing
Hello Mohammed,
Here are two screenshots. One is the manual shipping method. It has no price ($0.0) because it is free shipping as standard for any product. I removed the restriction Zone: Australia for testing purposes.
The other one is a screenshot of a product that I use for testing.
Edward
- Thank you received: 1778
11 years 6 months ago #198819
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Shipping Method Not Showing
Your issue is probably coming from the fact that you have a warehouse on your product configuration page, the solution will be to :
- set the same warehouse on your shipping methods
OR
- remove that warehouse from your product configuration page.
OR
11 years 6 months ago #198928
by buffdownunder
Edward
Dear Mohammed,
your hunch was right. It was the warehouse in the product configuration page.
What I don't understand now is what the field is for? I want to set up warehouse locations in preparation for Hikamarket and Multivendor.
Edward
Edward
Edward
11 years 6 months ago - 11 years 6 months ago #198960
by Mohamed Thelji
That field will enable you to split your products through your checkout workflow so that your product will be sent through multiple group and by different shipping methods/...
Last edit: 11 years 6 months ago by Mohamed Thelji.
11 years 5 months ago #199179
by buffdownunder
Edward
Aaah,
Thanks for the info, Mohammed. So how do I use it correctly then? Do I need minimum two warehouses for it to work?
Edward
Edward
Edward
11 years 5 months ago #199237
Replied by nicolas on topic Re: Shipping Method Not Showing
It depends what you want to do exactly.
But yes, you want to assign one of the warehouses for each product. Then, make sure that you have at least one shipping method for each warehouse.
The following user(s) said Thank You: buffdownunder
Time to create page: 0.169 seconds
