Category listing pane sliders always open problem
12 years 6 months ago #156365 by Nihilus
I enabled debug mode and the accordion menu worked 100%. I disabled the debug mode again and I will update the Hikashop later today and let you know if this helped.
Thank you
12 years 6 months ago #157372 by Nihilus
Hello
Sorry for the delay. Got caught up in other work.
As previously mentioned; When the debug mode is enabled, the accordion menu works perfectly. I updated hikashop business to 2.3.1 and disabled the debug mode but, *sigh*, the problem persists.
Where can I get the js and where can I add the js? I'm a junior developer, so please take it easy on me :D
Thanks again for your time and effort in this matter!
12 years 5 months ago #157725 by Xavier
Thanks to disable the debug mode, use the Shortut "Ctrl + U" get the source code opened, then enable the debug mode, and press again this shortcut. Thanks to compare the difference between the two source codes, you should see a missing javascript library in one of the sources in the head part.
