- Thank you received: 14307
Products not showing when linked from Category
acepubdev.ace-canada.com/fr/agriculture/...44451/name-animalacc
Just the first category should work. Forexample in the top menu select: Agriculture/Animal Acc/Animal acc divers
If you need to acces the back end let me know
I still do not see any products when I select the Animal acc divers link
The problem is probeble related to the fact that there is no associated module on the last menu level: Animal Acc divers.
How to fix it if it is really the problem.
And since the associated modules are responsible for the display of the listing products, that's normal that you didn't get any listing of products.
I've reverted your change and it's working as expected.
I will say it is part of our learning curve.
Thanks a lot for your help.
Edit: I managed to receive the prompt by deleting and remaking the menu items.
It seems strange that the component is not displaying the products without having the modules, unless you have menu items straight to products. And that the only way to create the modules is by saving the menu item. However as long as it works I won't complain
These modules are generated automatically so it's not really a problem as long as you don't delete them... That enables you to set different display settings between the listing of categories and the listing of products.
nicolas wrote: You need to understand how it works:
When you create a listing of categories menu, the options of the menu apply to the listing of categories. The listing of products which is attached to the menu is displayed by the associated module and uses the options of the associated module. So it's normal that the menu has a type of content of category and the associated module a type of content of product since the first one is displaying the categories and the second one the products in the categories.
So, if you turn off the associated module, the system will detect that you're trying to display a listing of categories without an associated module to display the products below it and it will create automatically a new associated module for it.
There is no cache on it, it's just a matter of understanding how it works.
That answered my question right there.
was wondering what all these associated thingy's were lol.
problem now is.. figuring out which associated_product_menu is associated with which category_menu. Tricky Business
I'm having the same problem again. When you click on the green stillettos, it takes you to a random page each time: buyandsellfashion.com/fashion-marketplac...ine/31-women-s-heels
Also, when you click on a product from the joomla xtc hikashop product wall module, the same thing happens: buyandsellfashion.com/
I went through and deleted all menus and modules, and started again by copying exactly the setup of another site that works properly, and the only thing that was different was that the correctly working site had no associated category menu selected (see attached) and the site that doesn't work properly, automatically has the product category selected, and when you delete it and save, it appears again.
Another thing I noticed was that the alias was not saving correctly either, but seems to be working now.
Thanks for your help!
Did you do any customization in the product view files ? If so, if you remove them, does it solves the problem ?
Alternatively, if you turn off the SEF in the joomla configuration, does it helps ? What are the URLs in that case ?
I removed all the customisations, and that didn't work, so then I turned off activate smaller url in hikashop, and now it works properly. Is there a way to fix this and still be able to use the sef urls?
Turning off the sef in Joomla config didn't make any difference FYI.
buyandsellfashion.com/fashion-marketplac.../33-green-stiletto-s
