- Thank you received: 14307
Products not showing when linked from Category
13 years 7 months ago #96213
Replied by nicolas on topic Re: Products not showing when linked from Category
It sounds like the issue is that the product SEF name and the category SEF name are not configured properly in the configuration of HikaShop and because of that, the SEF system is not able to distinguish between the product details page and the products listing page.
Could you do a screenshot of the whole SEF options area of the configuration of HikaShop ?
13 years 7 months ago - 13 years 7 months ago #96286
by Bugger101
Replied by Bugger101 on topic Re: Products not showing when linked from Category
Removed the dash and works perfectly, thanks so much Nicolas
Last edit: 13 years 7 months ago by Bugger101.
13 years 6 months ago #103406
by Kerstin
Replied by Kerstin on topic Products not showing when linked from Category
Hi!
I'm new in Hikashop. Using Business edition on local host.
Created some categories and products.
Then created a content module and additional menu Items in Joomla to all categories (category listing) and seperatly to each category to test everything.
Everything worked fine.
After configurating CSS I added two new Subcategories.
Structure:
Root > Product Category > Categorie 1> Subcategory 1, Subcategory2, new Subcategory3, new Subcategory4
There is no way displaying the two new Subcategories using category listing (not via content module and not using menu Item)
But using a menu Item linked to 'category listing' category 1 all subcategories including the two new are displayed
Tried:
Unpublishing associated module
remove Category listing override
disabled SEF in Joomla and Hika
deleted associated module
made a new Category listing menu Item
Thank you in advance
Structure:
Tried:
13 years 6 months ago #103411
by Jerome
Replied by Jerome on topic Products not showing when linked from Category
If you want to display all categories, you have to set the option "sub element filter" to "all sub elements" and not "direct sub elements".
Otherwise, you can click on the category in order to enter into. At this moment you will see the sub categories of the selecting category.
13 years 6 months ago #103413
by Kerstin
Thank you for your quick reply.
Sorry, my explanation wasn't clear:
I just want to display the direct subcategories and that works. So in my content I see Category 1 and Category 2 and Category3.
But when I click in my content on the Category 1 only subcategory1 and Subcategory2 appear, not Subcategory 3 (new) and not Subcategory 4(new)
The same problem in my content module: all categories are displayed, but clicking on Category 1 only the two older Subcategories are listed in the module
13 years 6 months ago #103415
by Jerome
You have the option "only display categories with products" selected.
I guess your two new sub categories does not contains products.
13 years 6 months ago - 13 years 6 months ago #103417
by Kerstin
Your guess was absolutely correct
I didn't notice it
Thank you very much!
I didn't notice it
Last edit: 13 years 6 months ago by Kerstin.
