Images not uploading
16 years 1 month ago #69 by manamaga
I have tried to add an image to my product but it wont upload after clicking OK, the lightbox goes white:
16 years 1 month ago #70 by manamaga
Replied by manamaga on topic Re: Images not uploading
How frustrating, my image is not showing in this post :(
16 years 1 month ago #71 by nicolas
Replied by nicolas on topic Re: Images not uploading
Which browser are you using ?
If you try on our demo website, do you have the same problem ?
16 years 1 month ago #72 by nicolas
When you post an image on the forum you need to include the tag
[img/]
in your message
16 years 1 month ago #73 by manamaga
Not tried your demo website. I am building a new website for my client and thought i would try this shopping cart, as all the others are either too much for what i need or too little. I wish i could post my screen shots. I am using IE8
16 years 1 month ago - 16 years 1 month ago #74 by manamaga
I think my screen shot image is too large, 1 min
Last edit: 16 years 1 month ago by manamaga.
16 years 1 month ago #75 by manamaga
My image is 249kb, is that too large?
16 years 1 month ago #76 by manamaga
16 years 1 month ago #77 by nicolas
It might be the resolution. I increased the limit on our forum to 2000*2000 where before it was limited to 800*800.
You can upload images up to 5MB.
16 years 1 month ago - 16 years 1 month ago #78 by manamaga
Step 2
16 years 1 month ago #79 by manamaga
Step 3
16 years 1 month ago #80 by manamaga
Result
16 years 1 month ago #81 by nicolas
I see that you are trying to add an image in the description of an image (you have two popups). I tested that on our demo website and it's working fine.
However, if you do not add an image in the image browse field below the description, nothing will be added. We should display an error message insted of a blank screen in the popup, but it's normal it doesn't work if you don't provide an image in the image browse field of the first popup coming on the screen.
16 years 1 month ago #82 by manamaga
Not sure i understand. If i click the +ADD image button on the right hand side, as in my last screen shot, i get a pop-up light box, where i browse for the image and click insert, nothing happens. Let me try again.
16 years 1 month ago #83 by nicolas
Yes that's normal.
After clicking on the Add button. You get a popup. There, instead of trying to add an image to the description field where you have the HTML editor by clicking on the Image button, you should add your image via the Browse button below the Image button of the HTML editor.
16 years 1 month ago #84 by manamaga
Ahhhh, OK, clicking the browse button will open local machine, choose image and click OK, it works. Clicking the 'image' button under the editor will open the server browser. So, its not possible to insert images which are already on the server, they have to be inserted from local machine?
16 years 1 month ago #85 by nicolas
Indeed.
16 years 1 month ago #86 by manamaga
Excellent! I have to say, thanks for the very quick replies. I will go and have a play around with the other settings now to see if i can get it working how my client would like. It is looking very good and i will have no problem recommending to others if this works. Many thanks!
16 years 1 month ago - 16 years 1 month ago #87 by manamaga
WOW, next problem, i added to cart then proceed to checkout, look what happened:
Also, is it possible to set so that the user does not have to register to buy?
16 years 1 month ago #88 by nicolas
We will try to add some javascript check on that to be sure the user selected a file when clicking on the OK button.
Concering the cart issue, it seems that the cart module translations were not found when trying to display the cart. It's strange because the translations are found on the main page.
Time to create page: 0.123 seconds
