Images not uploading
16 years 1 month ago #109 by manamaga
Replied by manamaga on topic Re: Images not uploading
Looks great now, thanks so much for your help in this. I`m working on the ftp in joomla now, i didnt realise i had not set this up :unsure: Thanks again.
16 years 1 month ago - 16 years 1 month ago #110 by manamaga
I`m having real trouble setting up how i want this to look. I`m beginning to think that this software is also too big for what i need but i really like the look and configurability of it and dont want to give up on it. I am wanting to have a link in the left column, for example 'Our Shop', when clicking this link there becomes underneath, sub menus like Coffee Tables, Soft Furnishings, Beds, etc, then when the user clicks a sub menu, they get all the items listed in that catagory appear on the right. I have been trying different settings and have read your tutorials for hours but there must be something i`m doing wrong.
Last edit: 16 years 1 month ago by manamaga.
16 years 1 month ago #111 by nicolas
Replied by nicolas on topic Re: Images not uploading
So I understand that you want a module which will display your categories. Then, when clicking on a category it will display a listing of its products.
That's exactly what we have on the demo website with the module "categories of products" which display the categories we have setted up and then when you click on a category, you get a listing of the products in that category.
In order to accomplish that, you first need to create a module displaying products which is synchronized (there is an option for that on the left part of the hikashop options of the module). Then, you need to create a category listing menu which you will leave unpublished and to which you will associate the module displaying the products thanks to the "associated module" option. Finally, you will want to create a module displaying your list of category. In its hikashop options, you will have to select the menu you previously created in the dropdown called menu.
That's explained by the last tutorial on this page www.hikashop.com/support/documentation/6...ml#categories_module in combination with the tutorial on how to create a listing of categories with a menu.
You can look at how we did it on our demo website which displays exactly what you want with the module called "categories of products".
16 years 1 month ago #112 by manamaga
I did try to follow that tutorial, there is obviously something i missed. I dont give up easily so i`ll give it another try! I think its just a case of taking plenty of time to get used to how this system works. I`ll report back soon :unsure:
16 years 1 month ago #113 by nicolas
You can try to use the same modules and menus options we have in the demo website. There is no reason you wouldn't get the same result.
16 years 1 month ago #114 by manamaga
Something still not working, i`m soory but it sounds like a really long way round to achieve what i`m wanting, create a module which displays a module which has catagoies etc etc. I have tried to follow the tutorial 4 times now and still dont get the result. I now have a 'Products' module in the left column which when clicked displays the catagories on the right column, i wanted it to display underneath, like sub-menus. Please could you check if i have set this up right? you are welcome to use the login details from yesterday.
16 years 1 month ago - 16 years 1 month ago #115 by nicolas
I set it up for you.
Basically, you didn't set the "menu" option of the categories module to the menu "products" you had created.
Also, I disabled your products module so that it doesn't display on the left (you want it only in the main page) and I change the products menu to a new menu called "no display" so that the "products" menu, while being used for the Itemid of the categories module links in order to tell the system how the page should display once you click on a category link, is not displayed on your website main menu.
Last edit: 16 years 1 month ago by nicolas.
16 years 1 month ago #116 by manamaga
I appreciate this so much. I really wish i understood what you just said :unsure: and i cant help but think that the tutorials could be a little more 'step by step' type of approach. Somehow, my cart seems to have changed so i`m going to see if i can get this back to how it was yesterday.
16 years 1 month ago #117 by nicolas
The display options of your cart module where on Off instead of On. I put them back On.
We need to make that process a bit simpler and the tutorial as well. You're right that it's not all that simple because you need to understand how joomla modules and menus work before following the tutorial. On the other end, when you know how to use the system, you can display stuff the way you want pretty much easily. Without having to hack in files, etc.
HikaShop is still young, so we will work on improving that stuff along the way :)
16 years 1 month ago #118 by manamaga
Absolutely, and as soon as i have time i will install HikaShop on my demo site on my local machine so i can have a play around with it. I have just one last question, is it possible to display only '£' instead of '£GBP', this would mean turning off 'GBP' if possible.
16 years 1 month ago #119 by nicolas
You need to go to the currency management listing hikashop menu System->Currencies. Then, you can edit the GBP currency. On the right part of the screen you need to change the display format from %ni to %n
More info on that at: www.hikashop.com/support/documentation/i...ncy-form.html#locale
16 years 1 month ago - 16 years 1 month ago #120 by manamaga
For your information, i`m finding it difficult to edit Zones. When i click 'System>Zones' then changes display to view 'All', my browser locks up and i cant make any changes:
Just to add that this doesnt happen in Firefox, only in IE8 it seems.
16 years 1 month ago - 16 years 1 month ago #121 by nicolas
That's normal. There are around 5000 zones by default in HikaShop. If you try to display them all on one page your browser will struggle to process all that information and result in the problem you had.
It's the same with any joomla listing when you have a lot of information in it.
If you want to unpublish countries, you should first select the filter on the right to countries. Then, when you select all, it will only display 200 items which should be ok.
You don't need to unpublish states of unpublished countries because by just unpublishing a country, all its states won't be displayable by your users.
16 years 1 month ago #122 by manamaga
Cool, though i found that when clicking to view 'All', firefox does actually cope pretty well and it only take a few seconds to process the info ;) Next question (sorry to keep asking), if i go to HikaShop>Configuration>Display>Custom Fields, i want to delete the fields which i dont need and reorder the ones that i do need, but nothing happens when i try to do this. The only thing it will let me do is to add new fields or amend existing fields, not delete or sort them into the correct order. Any advice on this?
16 years 1 month ago #123 by nicolas
It's not allowed to delete default fields. However, you can upublish them. Ordering should work although I must say we didn't test the ordering on this particular listing so there could indeed be a problem... Thanks for the report... We'll look deaper into that on monday and fix what needs to be fixed.
16 years 1 month ago #124 by manamaga
I only wanted to delete unused fields just to keep things tidy at the backend but thats fine, i`ll just unpublish them. Ordering would be good if you could let me know when there is a fix available, i`m hoping to hand over the website by the end of next week to my client.
16 years 1 month ago #125 by nicolas
We have found the problem already and corrected it on our development version. We also added an error message when deleting a core custom field so that it's less confusing.
We will release all those fixes along with others tomorrow.
16 years 1 month ago #126 by manamaga
Once again, you are a star!! :woohoo:
16 years 1 month ago #133 by nicolas
The new version of HikaShop is available. You can download it and install it without uninstalling the previous version.
It fixes a lot of small things you reported and the ordering bug on custom fields.
How to update documentation:
www.hikashop.com/en/support/documentation/59.html#update
16 years 1 month ago #135 by manamaga
Thanks for the quick update, i have installed this but joomla throws up some errors after clicking install:
Time to create page: 0.109 seconds
