Images not uploading
16 years 1 month ago #136 by nicolas
Replied by nicolas on topic Re: Images not uploading
That's because those plugins are the only files for which I didn't correct the access rights last time. Thus, joomla was not able to overwrite them now that you activated the FTP layer (because the FTP user doesn't have access to those files, only the web server has). That's basically the problem I was talking about when I warned you that you should use the FTP layer.
Anyway, those files were not changed between 1.0.5 and 1.0.6 so you can ignore the error messages. HikaShop will function properly.
16 years 1 month ago #137 by manamaga
Replied by manamaga on topic Re: Images not uploading
OK cool, i did get onto the webhost to change the owner of files and he assured my that it had been put right.
I have just published the hikashop products / category search plugin but it doesnt seem to appear on the website. Is the plugin included with the starter edition?
16 years 1 month ago #138 by nicolas
The search plugins just hook themselves to the standard joomla search. So once you published the search plugins you also need to publish the joomla search module which will handle the display.
16 years 1 month ago #139 by manamaga
;) Thanks, i think i`m nearly there. I have been given some breathing space in terms of when i hand the website over. I am meeting with my client on Wednesday to collect all his product info and images so i can populate the cart and do test purchases. I probably have another 2 weeks or so. I`ll let you know if i have any problems with checkout etc.
16 years 1 month ago #158 by manamaga
ok, i did the update last night and have just come to try to re-order the catagories but it still wont let me re-order. It let me move only one catagory once and now it seems it doesnt want to move anymore. The page will refresh but nothing has changed.
16 years 1 month ago #159 by nicolas
I was indeed able to reproduce the problem on our dev website. We will correct that ASAP.
16 years 1 month ago #160 by nicolas
We put a new version online which fixes the problem among other things.
16 years 1 month ago - 16 years 1 month ago #176 by manamaga
Thanks for the quick update, however, when i install update i get error. I have tried joomla auto installer and also via the .tmp folder, this is the error
Just had a thought, i`m at work at the moment (behind proxy), i will try when i get home.
Last edit: 16 years 1 month ago by manamaga.
16 years 1 month ago #177 by nicolas
That's an error pertaining again to joomla and access rights. You can follow the thread below on the acymailing forum where someone else had exactly the same issue and solved it:
www.acyba.com/en/support/forum/2-bug-rep...mailing-starter.html
16 years 1 month ago #182 by manamaga
Just to let you know, its fixed :silly: thanks! Now i have to work on the checkout page width as mentioned earlier in this thread, i`ve not had a chance to make the changes yet.
Time to create page: 0.121 seconds
