Difference from invoice and cart value with coupon
14 years 3 months ago #53502
Hello, I'm using version 1.5.8 with Apply discounts before tax and price_with_tax set to no tax. I configured a 50% coupon.
In checkout I correctly get:
- product 100€
- coupon 50€
- vat (20%) 10€ - correctly (100-50) * 20/100
- total 60€
But order/invoice shows:
- product 100€
- coupon 60€ (!)
- vat (20%) 20€ (!)
- total 60€
Why is there this difference? If I choose Apply discounts after tax, the order/invoice doesn't change and the checkout works as expected.
I need order/invoice and administration to be like in the checkout, how can I do that?
Thanks!
  • Thank you received: 14211
14 years 3 months ago #53579
We changed the taxed prices display system in the latest version so that it is easier to handle.
You must have edited the file "invoice" of the view "order" before updating HikaShop to the latest version right ?
In that case, you could remove your customization and that should then fix the problem automatically.
14 years 3 months ago #53586
I installed version 1.5.7, then upgraded to 1.5.8.
After that, I made a small customization in templates/mytheme/html/com_hikashop/order/show.php starting from 1.5.8 file version.
I didn't create administrator/templates/bluestork/html/com_hikashop/order/invoice.php and didn't changed the original file.
I made some test checkout, but the problem is still there.
Should the problem be fixed also for old orders or just the new ones?
Thank you!!
14 years 3 months ago #53679
That's really strange... The VAT line is displayed before the coupon line in the invoice and the taxes display works fine on our end in the invoice. I don't see how you can get such results.
Can you do a screenshot ? Maybe we're not talking about the same thing here.
14 years 3 months ago #53755
I made some more investigation, also using your online demo. I chose Apply discounts before tax, configured a tax for Black shoes and wheel, but I got a strange behaviour: in the cart/checkout, if Show taxed prices is set to both under System-Configuration-Display the coupon is calculated on price VAT included, if it's set to No tax the coupon is calculated on price VAT excluded. It should always be VAT excluded because of Apply discounts before tax. I couldn't finish the checkout, I don't know why (click on next simply refreshed the page), so I don't know about the order/invoice.
Anyway I attached some screenshot of my environment, I made small graphical changes but it shouldn't be a problem.
14 years 3 months ago #53812
It looks like it has something related to line 1150 in components/com_hikashop/controllers/checkout.php
$discount_price=@$cart->coupon->total->prices[0]->price_value_without_discount_with_tax-@$cart->coupon->total->prices[0]->price_value_with_tax;
The discount calculation saved in order_discount_price field in db should depend on "Apply discounts: after/before tax", but now it looks like it's always after tax.
Could this be the problem?!
Last edit: 14 years 3 months ago by Ciovo.
  • Thank you received: 9
14 years 3 months ago #53817
We have the coupon discount value showing the coupon amount plus the amount that accounts for shipping and tax savings.
The end total is correct when we use a coupon, but it is confusing to our customers to see a coupon value that is higher than they are expecting to see. Also makes accounting reports difficult to figure out.
For example:
If we have a product that normally sells for $100 and a coupon for 50% off, then we want to see the coupon value displayed as $50.
Instead it shows a higher value for the coupon in to account for tax and shipping savings.
The total is correct at $50, but it is really weird to see more than $50 for the coupon total value.
Is there a way to make it so the coupon value is just $50 on a 50% discount off a product that costs $100?
We don't want shipping and tax to be figured into the coupon value that is displayed, just the 50% off the order subtotal.
Ecommerce expert for hire. DaveKarlsven.com
I love helping businesses make lots of money online.
Last edit: 14 years 3 months ago by wildfire.
14 years 3 months ago #53937
@Ciovo :
If you can't finish an order during the checkout, you should have an error message. If you don't it's probably because of your template:
www.hikashop.com/en/support/documentatio...issues.html#messages
Also, it means that you either have a problem with your shipping methods or with your payment methods setup:
www.hikashop.com/en/support/documentatio...ins-listing.html#faq
Regarding the storing of discounts in the orders, it's possible that in some cases, we might need to store the calculation without taxes.
Could you try with that line instead:
$discount_price=@$cart->coupon->total->prices[0]->price_value_without_discount-@$cart->coupon->total->prices[0]->price_value;
@wildfire :
The coupon never takes into account shipping as the shipping is added after the coupon.
Regarding taxes for coupons, there are two options that manage that: The "Apply discounts: after/before tax" option of the configuration AND the tax category of the coupon itself.
Both results should be possible by changing these two options. I think that when the discounts are applied after taxes, you should not select a tax category, but when the discounts are applied before taxes, you should select a tax category.
14 years 3 months ago #53939
nicolas wrote: @Ciovo :
When I made this test, I was working on your online demo site, so if there's a problem it's not related to my template (maybe some reset of the db at fixed time?!).
In my environment I don't have shipping because I sell services, and payments seems to work without problems.
nicolas wrote: Regarding the storing of discounts in the orders, it's possible that in some cases, we might need to store the calculation without taxes.
I'll try and I'll let your know if it works as expected.
Thanks again!
14 years 3 months ago #54005
There is no errors on that end on our demo website.
However, the demo website is reset once every hour. At that point, the pages won't display while the website is reset and such errors could occur. Nothing to worry about. Just try again a few minutes later.
14 years 2 months ago #54113
Thanks again!
Calculations and order/invoice is now as expected and reflects what appear in the checkout, so this problem is solved with this change.
Anyway, after this I had to override the subtotal calculation in administrator/templates/bluestork/html/com_hikashop/order/form.php in order to take into account the different behaviour. From
<?php echo $this->currencyHelper->format($this->order->order_subtotal,$this->order->order_currency_id); ?>
to
<?php $taxes = 0;
if (/*$this->config->get('detailed_tax_display') &&*/ !empty($this->order->order_tax_info)) {
   foreach ($this->order->order_tax_info as $tax) {
      $taxes += (double)str_replace(',', '.', $this->currencyHelper->format($tax->tax_amount,$this->order->order_currency_id));
echo $this->currencyHelper->format($this->order->order_subtotal - $taxes,$this->order->order_currency_id); ?>
It's working now, but I strongly suggest to parametrize this option because the boss I'm working with in this project said to me it was a must for the Italian law.
Thank you for you important support!!
14 years 2 months ago #56420
I still have some problem after this change.
If I order two items:
- 100 euro, full price
- 10 euro with a 50% discount coupon (Coupon percentage applies to product only to yes)
I get:
total: 110 euro
discount: 5 euro
vat (21%): 23.1 euro (=110*0.21 instead of 22.05=105*0.21)
final: 128.1 (=105+23.1 instead of 127.05=105+22.05)
It looks like
$discount_tax = $cart->coupon->total->prices[0]->price_value_with_tax-$cart->coupon->total->prices[0]->price_value;
is making a wrong calculation, especially the value of price_value_with_tax which is calculated after taxes, even if I set the Apply discounts before tax.
How can I change the code to make price_value_with_tax and discount_tax work as expected?
Thank you!
14 years 2 months ago #56474
I tried on my end and I get the correct result without any code change:
I set the discounts to be before taxes in the configuration, the coupon to be in the tax category and the products with the exact same settings than you did.
14 years 2 months ago #56507
nicolas wrote: I set [..] the coupon to be in the tax category
That's what I missed!!
Thank you again for your great support!
14 years 2 months ago #56666
I still have some problem with variants using a 50% coupon.
If I choose a category in the coupon configuration, it looks like the discount for variants are calculated with this formula: price_variant * 50% + price_product.
Product: 20, you buy variant a at 20, you get 20 discount (and not 10)
Product: 20, you buy variant b at 40, you get 30 discount (and not 20)
Product: 30, you but a variant c at 170, you get 150 discount (and not 135)
If I choose a product in the coupon configuration, it looks like the discount for variants are calculated only on the price of the product.
Product: 20, you buy a variant b at 20, you get 10 discount (it's correct but the two prices are the same)
Product: 20, you buy a variant b at 40, you get 10 discount (and not 20)
Product: 30, you buy a variant c at 170, you get 15 discount (and not 135)
In both cases, I'm checking "Coupon percentage applies to product only" to yes because the discount should be applied only to the product into the selected category or variant.
Am I missing something? Thanks!!
14 years 2 months ago #56957
That's because you're setting the price in the main product.
If you only set it in the variants, it should work fine.
Edit the file administrator/components/com_hikashop/classes/discount.php and change the lines:
foreach ($products as $product) {
$variantsFirst = array_reverse($products);
foreach ($variantsFirst as $product) {
in the function recalculateDiscountValue(&$coupon,&$products,&$id) and that should fix the problem for products with variants and the prices defined both in the main product and in the variants.
14 years 2 months ago #56982
Thank you, now coupon works properly but only if a product or category is specified.
If a coupon is for all product, the discount value is correct but VAT and total are wrong.
Example: price 100, discount 50% = -50, vat is not displayed (it's a negative value, should be 10.5) and total is 47,79 (should be 50*1.21=60,5)
The same coupon works correctly if the same product is specified in the coupon.
Would it be possible in the future to assign a coupon to a variant? And what about multiple products/variants? It would be very useful!!
Thanks again.
14 years 2 months ago #57027
Can you do a screenshot of the options of your coupon ?
So that we can try to reproduce the problem.
We could potentially add the possibility to assign coupon to variants yes.
You can already assign a coupon to several products. Just use an unpublished category for that and add it as second category to the products.
14 years 1 month ago #57751
nicolas wrote: Can you do a screenshot of the options of your coupon ?
This is the coupon when no product/category is specified.
The other coupon is the same except product or category and "Coupon percentage applies to product only" set to yes.
14 years 1 month ago #58187
Did you find something strange? Should I provide you more details?
Thanks!
Time to create page: 0.355 seconds
