Cart not showing product with custom field upload
15 years 4 months ago #12691
My cart works fine except when I publish the custom field in order for my customer to upload their picture, the cart doesn't show the product and quantity.
Thank you for your prompt answer.
version hikashop 1.4.7.
  • Thank you received: 14186
15 years 4 months ago #12701
Could you give a link to your shop so that we can see the problem ?
15 years 4 months ago #12823
I can't give you a link as I am working on a localhost.
15 years 4 months ago #12842
Could you do a screenshot of the problem then ?
15 years 4 months ago #12852
Please find herewith my screenshot. I precise that I uploaded many pictures jpg - size under 2 Mo.
The file appears well in the search field but when I clic on the add to cart button the product informations diseappears into the cart.
15 years 4 months ago #12854
My screenshot herewith
15 years 4 months ago #12856
My screenshot again. Hope the file will upload
15 years 4 months ago #12882
As we can't reproduce the problem on our end, it will be hard to help you without being able to access your website.
Would you be able to put your website online ?
