Products and Characteristics
15 years 4 months ago #14510
When I define a product and add a characteristic to that product, I can save this. Later on, when I change the characteristic, I am no longer able to save the product. What I get is "Product with the same code still exists. Save Error"
What do I do wrong or how to solve that.
Kind regards
  • Thank you received: 14186
15 years 4 months ago #14535
You can only have one product (or variant) with a specific product code. If you get that error, it's because you have already a product/variant with the same name as the product saved (or the variants generated).
15 years 4 months ago #14568
Right. But what if I change now one of the variants. Lets say I have a product table and the variants are green, yellow and gray. If I change now gray to black.
In this case I do have a product/variant with table/yellow and table/green.
How to deal with this?
And what exactly it the code? Is this the product code? As I understand, the ID's are taken in the database tables.
I even can not change anything in the description, I can not assign nor delete categories and characteristics. Which means: I am not able to change anything.
Kind regards
Wolfgang
Last edit: 15 years 4 months ago by Wolfgang.
15 years 4 months ago #14575
You need to click on the "manage variants" button of your product. You will see the list of variants and you will be able to unpublish/delete the ones you don't need and/or add ones you're missing.
Yes, the code is the product code. If you can't save a product, it's either because the code of the product already exists or the code of a variant of the product already exist. Changing them should solve the problem...
15 years 4 months ago #14577
I did this. If I click on manage variants, I get the same Error. As I said before, I can not change anything. Click on Delete Characteristic, Delete Category, Edit the text or change "Disply contact button on product page" leads me to this error too.
15 years 4 months ago #14580
Could you try to activate the joomla debug mode in the joomla configuration and try again ?
Do you get additional error messages ?
15 years 4 months ago #14581
This is what I get:
JDatabaseMySQL::query: 1054 - Unknown column 'product_contact' in 'field list' SQL=UPDATE `itvp_hikashop_product` SET `product_name`='Installation und Konfiguration von Windows 7 Clients',`product_url`='www.microsoft.com',`product_meta_description`='MOC 6292, MOC6292, 070-680, 70-680, 070680, 70680 Installation und Konfiguration von Windows 7 Clients,',`product_keywords`='MOC6292',`product_code`='MOC6292',`product_tax_id`='21',`product_sale_start`='',`product_sale_end`='',`product_contact`='0',`product_quantity`='-1',`product_min_per_order`='0',`product_max_per_order`='0',`product_weight`='0.000',`product_weight_unit`='kg',`product_length`='0.000',`product_width`='0.000',`product_dimension_unit`='m',`product_height`='0.000',`product_published`='1',`product_access`='all',`product_group_after_purchase`='',`product_type`='main',`product_description`='
15 years 4 months ago #14582
Ok. That's another problem then.
Normally, if you update to version 1.4.9 of HikaShop, that should solve the problem automatically.
Otherwise, that solution will do it: www.hikashop.com/support/forum/3-bug-rep...t.html?lang=en#12117
15 years 4 months ago #14586
Looks good, I think that's it.
Thank you.
Kind regards
Wolfgang
