currency switcher module with SEF still not work
14 years 10 months ago #27078
I just upgraded to version 1.5.4 in the hope that The currency switcher module with SEF activated was broken by last release would be solved.
Unfortunately it is still not working on my site, which uses sh404SEF.
Any idea what could be the reason?
Gert
  • Thank you received: 14188
14 years 10 months ago #27084
Which version of joomla and sh404sef are you using ?
Could you try to activate the debug mode in the joomla configuration and try again ?
Do you get some error message ?
That would help in understanding the problem you're having.
14 years 10 months ago #27168
Hi Nicholas,
Joomla 1.5.23
sh404SEF 2.3.0.988
I was on the page where all products in the category silverware were shown in THB.
Then I used the currency switcher to go to USD.
With SEF disabled everything goes fine but with SEF enabled Hikashop goes back to the main shop page which shows all categories and the currency remains at THB.
This is what the log says:
Profile Information
Application afterLoad: 0.000 seconds, 0.39 MB
Application afterInitialise: 0.118 seconds, 5.78 MB
Application afterRoute: 0.216 seconds, 10.02 MB
Application afterDispatch: 0.499 seconds, 19.97 MB
Application afterRender: 0.703 seconds, 22.83 MB
Memory Usage
24141824
107 queries logged
SELECT *
FROM jos_languages
WHERE active=1
ORDER BY ordering
SELECT oldurl, newurl
FROM jos_redirection
WHERE oldurl = 'shop.html'
ORDER BY rank ASC
LIMIT 1
UPDATE jos_redirection
SET cpt=(cpt+1)
WHERE `newurl` = 'index.php?option=com_hikashop&Itemid=22&lang=en&layout=listing&view=category'
AND `oldurl` = 'shop.html'
SELECT m.*, c.`option` AS component
FROM jos_menu AS m
LEFT JOIN jos_components AS c
ON m.componentid = c.id
WHERE m.published = 1
ORDER BY m.sublevel, m.parent, m.ordering
SELECT jf_content.reference_field, jf_content.VALUE, jf_content.reference_id, jf_content.original_value
FROM jos_jf_content AS jf_content
WHERE jf_content.language_id=1
AND jf_content.reference_id IN(1,31,2,22,36,23,37,26,38,27,35,10,28,39,47,33,34,40,41,42)
AND jf_content.reference_table='menu'
FROM jos_menu AS m
SELECT id, parent_id, VALUE, name, lft, rgt
FROM jos_core_acl_aro_groups
WHERE id=23
SELECT *
FROM jos_hikashop_config
SELECT template
FROM jos_templates_menu
WHERE client_id = 0
AND (menuid = 0 OR menuid = 22)
ORDER BY menuid DESC
LIMIT 0, 1
SELECT *
FROM jos_menu
WHERE id = '22'
LIMIT 1
AND jf_content.reference_id IN(22)
SELECT *
FROM jos_modules
WHERE id IN (92);
AND jf_content.reference_id IN(92)
AND jf_content.reference_table='modules'
SELECT category_id
FROM jos_hikashop_category
WHERE (category_access = 'all' OR category_access LIKE '%,25,%')
AND category_type='product'
AND category_id IN (15)
AND jf_content.reference_id IN(15)
AND jf_content.reference_table='hikashop_category'
SELECT *
WHERE category_id = '15'
LIMIT 1
SHOW TABLES
SELECT *
FROM jos_languages
SELECT oldurl, dateadd
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&format=feed&lang=en&layout=listing&type=rss&view=category'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&format=feed&lang=en&layout=listing&type=atom&view=category'
SELECT a.*
FROM jos_hikashop_category AS a
WHERE a.category_parent_id = 15
AND a.category_published=1
AND (a.category_access = 'all' OR a.category_access LIKE '%,25,%')
ORDER BY a.category_ordering ASC
LIMIT 0, 72
AND jf_content.reference_id IN(43,48,42,18,22,19,25,27,24,17)
SELECT *
FROM jos_hikashop_file
WHERE file_type='category'
AND file_ref_id IN (43,48,42,18,22,19,25,27,24,17)
SELECT COUNT(*)
SELECT a.*,b.*
LEFT JOIN jos_hikashop_file AS b
ON a.category_id=b.file_ref_id
AND b.file_type='category'
WHERE a.category_id = 15
LIMIT 1
SELECT DISTINCT b.*
LEFT JOIN jos_hikashop_category AS b
ON a.category_left >= b.category_left
WHERE b.category_right >= a.category_right
AND a.category_id=15
ORDER BY b.category_left
AND jf_content.reference_id IN(1,2,15)
SELECT *
FROM jos_hikashop_field AS a
WHERE a.`field_published` = 1
AND a.`field_frontcomp` = 1
AND a.field_table='category'
AND (a.field_access = 'all' OR a.field_access LIKE '%,25,%')
AND ((field_with_sub_categories=0
AND (field_categories="all" OR field_categories LIKE '%,15,%'))OR (field_with_sub_categories=1
AND (field_categories="all" OR field_categories LIKE '%,1,%' OR field_categories LIKE '%,2,%' OR field_categories LIKE '%,15,%')))
ORDER BY a.`field_ordering` ASC
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=43&ctrl=category&lang=en&name=silver-jewelry&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=48&ctrl=category&lang=en&name=silk-shawls&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=42&ctrl=category&lang=en&name=ceramics-vases&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=18&ctrl=category&lang=en&name=ceramics-home-decor&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=22&ctrl=category&lang=en&name=ceramics-tableware&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=19&ctrl=category&lang=en&name=ceramics-bencharong&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=25&ctrl=category&lang=en&name=laquerware&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=27&ctrl=category&lang=en&name=woodcarving&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=24&ctrl=category&lang=en&name=bronzeware&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=17&ctrl=category&lang=en&name=aluminum-relief-panels-&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&cid=15&ctrl=category&lang=en&task=listing'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&lang=en&layout=listing&view=category'
SELECT category_id
SELECT *
FROM jos_hikashop_filter
WHERE filter_published = 1
ORDER BY filter_ordering
SELECT DISTINCT b.*
SELECT a.*,b.*
LIMIT 1
SELECT DISTINCT b.*
FROM jos_hikashop_product_category AS a
LEFT JOIN jos_hikashop_product AS b
ON a.product_id=b.product_id
WHERE b.product_published=1
AND b.product_type = 'main'
AND a.category_id IN (15)
AND (b.product_access = 'all' OR b.product_access LIKE '%,25,%')
ORDER BY a.ordering ASC
LIMIT 0, 72
SELECT COUNT( DISTINCT b.product_id)
SELECT id, title, module, POSITION, content, showtitle, control, params
FROM jos_modules AS m
LEFT JOIN jos_modules_menu AS mm
ON mm.moduleid = m.id
AND m.access <= 2
AND m.client_id = 0
AND ( mm.menuid = 22 OR mm.menuid = 0 )
ORDER BY POSITION, ordering
AND jf_content.reference_id IN(104,17,145,133,76,98,97,128,129,136,106,24)
SELECT *
FROM jos_languages
WHERE active=1
ORDER BY ordering
FROM jos_menu AS m
WHERE jf_content.language_id=2
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&lang=nl&layout=listing&view=category'
WHERE newurl = 'index.php?option=com_hikashop&ctrl=currency&lang=en&task=update'
SELECT *
FROM jos_hikashop_currency
WHERE currency_published=1 OR currency_displayed = 1 OR currency_id IN ('155')
SELECT a.*
FROM jos_hikashop_cart AS a
WHERE a.user_id = 62 OR a.session_id = '73a92ce5b00488a55e03909f8b4d3a09'
ORDER BY a.cart_modified DESC
LIMIT 1
WHERE newurl = 'index.php?option=com_hikashop&Itemid=22&ctrl=checkout&lang=en'
WHERE newurl = 'index.php?option=com_hikashop&ctrl=product&lang=en&task=updatecart&tmpl=component'
SELECT *
AND a.field_table='item'
SELECT category_id
SELECT a.*
LIMIT 0, 72
SELECT *
SELECT COUNT(*)
SELECT *
FROM jos_acymailing_config
WHERE newurl = 'index.php?option=com_acymailing&ctrl=sub&formid=129&lang=en&task=display&tmpl=component'
WHERE newurl = 'index.php?option=com_content&Itemid=2&id=2&lang=en&view=article'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=23&lang=en&layout=listing&view=category'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=26&lang=en&layout=step&view=checkout'
WHERE newurl = 'index.php?option=com_content&Itemid=27&id=23&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=35&id=33&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=10&id=44&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=28&id=2&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=39&id=29&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=47&id=50&lang=en&view=article'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=33&lang=en&layout=step&view=checkout'
WHERE newurl = 'index.php?option=com_content&Itemid=34&id=40&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=40&id=23&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=41&id=46&lang=en&view=article'
WHERE newurl = 'index.php?option=com_content&Itemid=42&id=47&lang=en&view=article'
SELECT CONCAT( 'search=', `search`, '
replace=', `replace`, '
area=', `area`, '
', `params` )
FROM jos_rereplacer
WHERE published = 1
AND area = 'component'
ORDER BY ordering, id
area=', `area`, '
', `params` )
FROM jos_rereplacer
WHERE published = 1
AND area = 'body'
area=', `area`, '
', `params` )
FROM jos_rereplacer
WHERE published = 1
AND area = 'everywhere'
WHERE newurl = 'index.php?option=com_user&lang=en&view=reset'
WHERE newurl = 'index.php?option=com_hikashop&Itemid=38&lang=en&layout=cpanel&view=user'
WHERE newurl = 'index.php?option=com_user&Itemid=36&lang=en&view=login'
WHERE newurl = 'index.php?option=com_phocaguestbook&Itemid=46&id=1&lang=en&view=phocaguestbook'
Language Files Loaded
/home/thaihand/public_html/language/en-GB/en-GB.ini 1
/home/thaihand/public_html/language/en-GB/en-GB.plg_system_debug.ini 1
/home/thaihand/public_html/administrator/language/en-GB/en-GB.plg_joomfish_missing_translation.ini 1
/home/thaihand/public_html/administrator/language/en-GB/en-GB.plg_system_cdscriptegrator.ini
/home/thaihand/public_html/administrator/language/en-GB/en-GB.plg_system_rereplacer.ini 1
/home/thaihand/public_html/administrator/language/en-GB/en-GB.plg_system_modulesanywhere.ini 1
/home/thaihand/public_html/language/en-GB/en-GB.com_hikashop.ini 1
/home/thaihand/public_html/language/overrides/en-GB.override.ini 1
/home/thaihand/public_html/language/en-GB/en-GB.mod_hikashop.ini
/home/thaihand/public_html/language/en-GB/en-GB.tpl_vs_asianlegend.ini
/home/thaihand/public_html/language/en-GB/en-GB.mod_breadcrumbs.ini 1
/home/thaihand/public_html/language/en-GB/en-GB.mod_jflanguageselection.ini 1
/home/thaihand/public_html/language/en-GB/en-GB.mod_customlogin_register_text.ini
/home/thaihand/public_html/language/en-GB/en-GB.mod_hikashop_currency.ini
/home/thaihand/public_html/language/en-GB/en-GB.mod_hikashop_cart.ini
/home/thaihand/public_html/language/en-GB/en-GB.mod_acymailing.ini
/home/thaihand/public_html/language/en-GB/en-GB.mod_valaddthis_15.ini 1
/home/thaihand/public_html/language/en-GB/en-GB.mod_mainmenu.ini 1
Untranslated Strings Diagnostic
None
Untranslated Strings Designer
None
14 years 10 months ago #27169
Could you give a link to your shop so that we can see the problem ?
14 years 10 months ago #27181
www.thai-crafts.com but SEF is currently disabled. Let me know what time you want to check so I can enable it
14 years 10 months ago #27182
Maybe you could give us a back end access to your website so that we can do that ourselves when we test and immediately turn it off once we're done ?
14 years 10 months ago #27183
Sure, will send you the login details by email.
14 years 10 months ago #27196
I don't know why but it seems that you had incorrect URLs in the cache of sh404sef. I just deleted them in the cache of sh404sef and then it had the correct URLs and it's now working.
14 years 10 months ago #27210
Was it that simple. I should have thought about that myself, but thanks a lot Nicholas!
