can't delete products and state won't show
14 years 8 months ago #27609
hello, I am using the version 1.5.0, version and on my shopping cart when you add a product and then you want to delete it, it won't allow it. also I am using the unites states as the main country and the state will not appear at all. I upgraded to latest version and the same thing happened. This all happened after I upgraded it to your last version.
14 years 8 months ago #27610
sounds identical to my issue which I described a couple of minutes ago in another post. No button in the checkout process works anymore. Does our order buttons still work at least?
14 years 8 months ago #27611
now, I managed to delete the products in the cart, but i do not get the buttoms when is says procee to check out.
what version are you using ? now, I gotta work to display the state of the country where the order goes.
14 years 8 months ago #27612
I use the latest one: 1.5.4
14 years 8 months ago #27613
i like using this shopping cart. we have to websites already but after i upgraded it to the lastest version, some glitches began like not showing the states
14 years 8 months ago #27614
what is your website address ? I am getting all the buttons at the end. go to configuration and see there. make sure your shopping cart is enabled it too.
14 years 8 months ago #27615
i am good at using this software. if you need help,write me to my email address. I like this shopping cart and it is better than virtuemart. I had it with virtuemart
  • Thank you received: 14092
14 years 8 months ago #27625
Could you try to download again the install package from our server and install it on your website again ?
Does that solve the problem ?
If not, could you activate the debug mode in the joomla configuration and try again ? Do you get any error message in that case ?
14 years 8 months ago #28223
hi, it did not solve the problem. i just downloaded the latest version and nothing happens.
the state will not appear. only the united states appear. here is my link
batasrobes.com/twill-spa-robes/checkout.html
14 years 8 months ago #28238
That problem is a SEF problem.
If you deactivate the SEF it will work.
For example that URL is working:
batasrobes.com/index.php?option=com_hika...tates_of_America_223
but the SEFed URL is not:
batasrobes.com/twill-spa-robes/checkout/...tates_of_America_223
What are you using to do the SEF on your website ?
14 years 8 months ago #28319
hello, i unplished it and still does not work.
what is causing this problem ? the state will no show up at all
14 years 8 months ago #28340
I tried to check your website but it seems it is down at the moment.
14 years 8 months ago #28722
i brought back the site again. I delete everything, i installed joomla again and then the hikashop and now i get the same problem.
here is the link.
also you can not delete a product after you place it on the shopping cart
batasrobes.com/component/hikashop/checkout.html
14 years 8 months ago #28757
Could you provide a back end access to your website ?
