Urgent! Need Help in Coupon Discount Setting
14 years 8 months ago #32191
Hi All, I am seeking for anyone can help as this is urgent, my sale has started and found my coupon over discount to customer! and, there is no coupon discount show on shopping cart after coupon was added. But when proceed to Paypal checkout page, the coupon discount rate is more then it should be?
I just upgraded from free version to essential.
Hope anyone can tell me which important field(s) in "Discount" I should take care after upgraded. I cannot find any guides about this.
I am using only one currency, and the setting is correct.
Thank you!
  • Thank you received: 14188
14 years 8 months ago #32192
Here is the documentation for coupons setup:
www.hikashop.com/en/support/documentatio...p-discount-form.html
Could you do a screenshot of your coupon's options so that we could check what is the problem ?
14 years 8 months ago #32198
Thank you Nicolas for fast response!
The 3 screenshot in shopping cart, paypal checkout page and in store coupon setting are attached. (1st is shopping cart didn't show coupon discount, I will add 2 screenshot in next 2 posts)
Also received an email from cart system title: "Paypal payment notification refused:invalid amount", the content is : "A Paypal notification was refused because the amount received (12.76SGD) is different from the order amount (22.33SGD)"
This amount is the real case customer paid, not the amount shown in screenshot, that was my example. Thanks!
14 years 8 months ago #32199
The 2nd screenshot is the Paypal checkout page:
14 years 8 months ago #32200
The last screenshot is the in store coupon setting:
Thank you!
14 years 8 months ago #32207
Oh yah, I have added some "Discount" for the X'mas sale after my upgrading to Essential from free version.
The amount I have mentioned above for that customer: "....(12.76SGD) is different from the order amount (22.33SGD)"
The $22.33 is the 30% discounted amount from the original amount $31.90 on the Sale".
The $12.76 is the amount the customer paid after she applied the coupon.
Hope this help!
14 years 8 months ago #32210
You should first try to turn off the "send order details" option in the paypal payment plugin. That will avoid that the amount paid in paypal is different than the amount of the order in HikaShop.
14 years 8 months ago #32220
I have set the Paypal plugin off, and tested another order with a $2 coupon. It still show Nil in the cart and Paypal checkout page didn't show any discount.
I went back to my tester account and view the order it show a VAT and a discounted amount same as VAT, pls see screenshot.
In my store, I have actually not required VAT, and I have turned off in the main configuration - "VAT number check" = "no check", is this right?
Thanks!
14 years 8 months ago #32222
After checking all my tester orders in my tester acct, I found all discounts were equal to the VAT amount.
Hope this help
Thanks! :laugh:
14 years 8 months ago #32225
Regarding my 2nd posts "Also received an email from cart system title: "Paypal payment notification refused:invalid amount", the content is : "A Paypal notification was refused because the amount received (12.76SGD) is different from the order amount (22.33SGD)"
Paypal account checking found no problem, I have received the amt of 12.76.
14 years 8 months ago #32230
After checking all my tester orders in my tester acct, I found all discounts were equal to the VAT amount.<- That's a bug which was corrected in the new release of HikaShop 1.5.5 it's strange that you're having that problem.
Could you try to replace the file administrator/components/com_hikashop/classes/discount.php by the one enclosed ?
14 years 8 months ago #32232
Sorry, where is the file?
14 years 8 months ago #32244
Sorry, the file had to be zipped.
14 years 8 months ago #32245
Thank you! So just upload from Cpanel or in the site admin backend?
14 years 8 months ago #32248
I would do that via FTP. If you don't have an FTP access, then cpanel should do the trick. If you don't have an extension like extplorer installed on your website, you won't be able to upload the file via your back end.
14 years 8 months ago #32259
No change at all.
Just a hint, I didn't use the default shipping zones, I created in the shipping some countries without states or city.
In the Hikashop main config page, the zone is 0.
Can this effected the discount system?
Thanks!
14 years 8 months ago #32265
That should not affect the discounts calculations.
If that doesn't work, I'm out of ideas. I would need from you an FTP access and a back end access to your website in order to debug the problem.
14 years 8 months ago #32403
I have forward the access.
Thanks!
14 years 8 months ago #32426
The problem has been fixed. It came from the fact that the products int he cart had already a discount on them and from the numerous modifications we had to make in the coupon system to handle the new options of HikaShop 1.5.5
We had to change a bit some code to make it work with prices with already discounts applied to them.
14 years 8 months ago #32491
Thank you very much, cheers :laugh:
