Breadcrumbs problem in product pages
14 years 4 months ago #45534
I am new to HIKASHOP. I use the business edition for my website at www.sottosub.gr (Greek Language). Breadcrumbs module (standard joomla module) seems to work ok for most pages. However when entering product pages from one main category i get wrong breadcrumbs that indicate my other main category and some subcategory of this. The two main Categories are "Κατάδυση" (diving products) and the other is "Κολύμβηση" (swimming products).
Whenever i enter some product page from the first category :"Κατάδυση" (diving products) i get breadcrumbs indicating the second category and a subcategory of this. The url indicates the wrong menu when i enter a product page from the first category and i cannot understand why (initial category and subcategory menu url is ok but product page url indicates wrong Category for Diving products)
You cas see the website HERE: www.sottosub.gr
  • Thank you received: 14189
14 years 4 months ago #45652
That's probably because you turned on the option "simplified breadcrumb" in the configuration. Please turn it off and it should display properly.
14 years 4 months ago #45782
I had not ever turned on the "simplified breadcrumb" in the configuration when i realized the problem exists. Then i tried turning this option on but nothing changed. Finally i turned this option Off but problem remained (this hapenned before my post). It must be something with menu assigment. I have setup two different menus for my products: One for the main menu at the top bar and one for the "ΠΡΟΙΟΝΤΑ" menu (light blue) at the right sidebar (sidebar-a template position). I remember i copied the menu;s and then used the automatic creation of modules and then adjusted the hikashop options separetely each one. I am sure thay the "simplified breadcrumb" option is set to "No". Problem still exists.
I JUST realized that this happens only if i select the product via the carousel (hikashop content module) and not from the normal listing of products below that. So the problem is related to the Hikashop content module....but i don't know what is wrong...maybe i have setup this module wrong?
Last edit: 14 years 4 months ago by Alexandrakis.
14 years 4 months ago #45783
I found a solution:
At Hikashop Content module for the carousel i Had enabled the synchronize option but i had made a selection for menu field. Removing this selection (selected "none") solved the problem.
See the attached image
14 years 4 months ago #45945
Thank you for the feedback.
14 years 3 months ago #49150
Hello everyone
Where is this "simplified breadcrumb" option located?
14 years 3 months ago #49175
Go to Hikashop backend.
Configuration --> Main tab --> SEF Url Options --> Simplified breadcrumbs
The following user(s) said Thank You: Eliot
12 years 6 months ago #142958
In my HikaShop v2.2.3 it is here:
Configuration --> Features tab --> SEF Url Options --> Simplified breadcrumbs
  • Thank you received: 403
12 years 6 months ago #143479
Thanks for helping guys!
8 years 5 days ago #297053
Hello, I am not sure if my problem is related however I have tried the suggestions in the thread.
My issue is that the breadcrumbs will get stuck on a parent category and not drill down with the visitor.
www.draganfly.co.uk/index.php/ariel/arie...y-optional-equipment
Any thoughts please.
Cheers
Iain
8 years 5 days ago #297065
That's the same issue indeed. You need to turn off the "simplified breadcrumb" setting to get the full category path in the breadcrumb.
Note however that for the setting to work, it has to add an extra parameter to the product page URLs. So if you have "canonical URL"s configured for your products with the "Force canonical URLs on listings" setting activated, then HikaShop won't be able to add that extra parameter since it will automatically use the canonical URL.
So in that case, a solution would be to either turn off that setting (the canonical URLs will still be taken into account by search engines so it's not a problem for SEO), or you could also clear the canonical URLs and enter them again with that extra parameter or let the system regenerate them with the "Use canonical URL and generate it if missing" of the "Force canonical URLs on listings" setting
8 years 3 days ago #297155
Hello NIcolas
Thank you for that. The Simplified Breadcrumbs was already turned off. I have tried the Force canonical urls in all settings to no avail. I am not sure how to clear the canonical URLS.
The other odd one would be this page
draganfly.co.uk/index.php/ariel/ariel/4-stroke
It shows a much deeper section
You are here: Home > Shop > 4 Stroke > Wheels & forks > Wheels > Rear wheel
whereas the page I am actually on is 4 Stroke.
Many thanks
Iain
8 years 2 days ago #297181
To clear the canonical URL of a product or category, you can edito that product or category in the backend, empty the field called "canonical URL" and then click on the "save" button. Once done, the link to that product or category on the listing should have that extra parameter called "category_pathway" which will allow the breadcrumb to show complete.
8 years 10 hours ago #297304
Thanks for that however the Canonical URL was already empty and I have looked for Pathway there isn't one. I tried putting something in Canonical URL and the saving, deleting then saving and nothing.
8 years 25 minutes ago #297306
First, check that you have disabled the cache for the Breacrumbs module of Joomla in the Joomla modules manager. If that module is cached, then it will always display the same path regardless of where you go and it seems that you have that problem.
Second, if the canonical URL field is empty and you don't see the category_pathway parameter in the URLs of the product page for your products, then it means that you need to clear some cache. Either the cache of the website pages, or the cache of the SEF URLs if you're using a SEF extension like sh404SEF, or both.
If I check the page draganfly.co.uk/index.php/ariel/ariel/4-.../724-battery-carrier for example, I see that the product 5860-51# doesn't have the parameter in the URL, but the product 5860-51BQ# has. That clearly indicate a caching issue or the canonical URL field not empty as both should either have it, or not have it.
Time to create page: 0.131 seconds
