control panel formatting gone a bit mad :)
  • Thank you received: 17
13 years 10 months ago #69605
Joomla 2.5.7 hikashop 1.6.0
My control panel has gone a bit mental, Im guessing I have changed some formatting somewhere by mistake, or something has gone wrong, can I have a pointer of where to check please ?
See below attachment for screenshot.
13 years 10 months ago #69669
Hi rikatos,
It's just a cache problem, try to clear the cache.
13 years 10 months ago #69674
It seems to be unique to chrome, as its fine in firefox. cleared cache, update chorme etc etc to latest and still does it there for me, but thats fine as I can use firefox for control panel.
  • Thank you received: 14190
13 years 10 months ago #69886
This display means that the CSS of HikaShop isn't found.
As Xavier said, clearing your browser cache should fix that unless the CSS of the backend of HikaShop has been deactivated in the configuration, but in that case, you should not be able to see the menu properly on FF either so I still believe that it's a caching issue.
13 years 10 months ago #70061
its not a problem, I cleared cache etc of all browsers, but I can see it fine in one so all is good for me :)
