Products
12 years 4 weeks ago #165592
I want to display my products next to each other like 4 or 5 on a row. Now
irt shows like this www.ncom.be/categories-listing/category/socket-1150
Something I forgot?
Best Regards, Wesley
12 years 4 weeks ago #165600
Your link does not work. I got a 404 page.
12 years 4 weeks ago #165616
hHi,
sry
www.ncom.be/hikashop-menu-for-categories...egory/21-socket-1150
I also have a dot point in front off my product. What is that?
Best Regards,
Wesley
12 years 4 weeks ago #165666
I have taken some pictures because it's wierd I can get it right and those point in front of every categories and products are like mixt-up.
  • Thank you received: 14186
12 years 4 weeks ago #165621
Both issues comes from the fact that you turned on the "use bootstrap design" option of the HikaShop configuration while your Joomla template is not compatible with bootstrap. Turn off the option and it will solve both.
12 years 4 weeks ago #165677
Thank you :-)
Ok that's one step. Now I want that the catogories only show in the left menu and not on my main page
Best Regards,
Wesley
Last edit: 12 years 4 weeks ago by Ncom.
12 years 3 weeks ago #165682
I do see it right under the other text: take.ms/6uoD9
12 years 3 weeks ago #165864
Yes I know but I don't want that the shop shows the categories de sub catogeries on my main page like in the screenshot above.
Because the categories al already in the left menu
12 years 3 weeks ago #165869
Does it solve your issue if you set the "Show sub categories" option of the category listing content menu which have the id number 109 to NO CHILD.
12 years 3 weeks ago #165972
no doesn't work. My left subcategories in the menu dissappears en in the main pages they stay. It's the otherway I want it.
Best Regards, wesley
12 years 3 weeks ago #166029
Then, you need instead to edit the left module (id 100) via the menu Display>content modules and set the "Link on main categories" option to "no". Then, it should work like you want.
12 years 3 weeks ago #166062
Thank you.
But now the arrow stands in the way lol. I think murphy is @ work :)
12 years 3 weeks ago #166253
This is just a CSS issue that you can easily solve by adding that CSS code on your website:
.pane-sliders h3.title span{ padding-left : 20px !important; }
12 years 3 weeks ago #166309
Thx,
And in witch file do I have to put it?
Best Regards
12 years 3 weeks ago #166339
As explained in the documentation link I gave, you can add it in the frontend CSS file of HikaShop via the Display tab of the configuration.
11 years 9 months ago #177292
I have a new Theme for my webshop but have some problems.
When I click on processors for example and then socket 1150 I getting a new black page.
I want them to show up next to my menu. I added some pictures so you can see what to
problem can be.
Kind Regards
11 years 9 months ago #177312
I just tested it and I'm correctly redirected to a product listing : www.ncom.be/menu/category/socket-1150
The following user(s) said Thank You: Ncom
11 years 9 months ago #177420
what I want is when I click for example on processors that it gives me a dropdown menu (categorie on 2 levels) and when I push
socket 1150 is give me the products next to my menu. Now I have like a menu with sub categories and a second menu that makes
Socket 1150, Socket 2011-V3, etc. that last I don't want that.
1. I need categories on 2 levels menu with subcategories in a dropdown menu
2. That my products show next to my menu. Now it just opens a new page
I hope this information is good enough to give me a good solution
kind regards
11 years 9 months ago #177422
So if I understand correctly, your problem is that the module of the categories on the left disappears when you click on a category ?
To avoid that, you need to edit your category module via the Joomla modules manager and make sure that you assign it to all the hikashop menu items, espcially the "hikashop menu for category listing").
11 years 9 months ago #177494
well kind of yes. But already fixed the menus now. but when I click for example processors --> Socket 1150 It just opens
a new windowpage (try it) but this is not how I want it. I just want when I click on it it just opens next to my menus
Time to create page: 1.310 seconds
