Need fast help with products custom fields variant
  • Thank you received: 114
9 years 2 months ago #270197
Hmm, strange but I don't use EDGE. I use Google Chrome and sometimes Firefox and IE11. On all browsers I see same. However one of our users is using EDGE only so could it be that system deactivates it per user account?
Does it work with you using different browsers?
Strange thing that there was no modifications and this are core files by default and it gives such issues...I am thinking to use old TinyMCE from Joomla 3.6.5. I hope it will work.
Many thanks
  • Thank you received: 14169
9 years 2 months ago #270199
No, it's not per account. It's on each page that the check is done.
For me it works regardless of the browser and only on edge, the tonyMCE editor doesn't display on the variants.
9 years 2 months ago #270270
So just to clarify. If I am using EDGE I should see as per this topic second screenshot attached?
www.hikashop.com/forum/content-creation/...-variant.html#269950
If I use any other browser. It should be same as on main product edition page?
9 years 2 months ago #270272
Actually no. On Edge, you should not see the editor at all. Just a normal text area. On other browsers you should get the same editor whether you're on the main product or the variant.
9 years 2 months ago #270328
Well i dont get it as you do :)
Anyway i am using editor from joomla 3.6.5 and it works perfect now.
Thanks Nicolas for taking your time in this matter.
Have a great weekend
