Div Product Display Problem
15 years 2 months ago #21320
Good Morning!
In testing different options in 1.5.2 I noticed that products displayed in div mode are not consistant. If there is an Add To Cart button, more space is underneath the button than if there is a Choose Options button. Since I'm a Code Dummy, what would I change to fix this?
Thanks,
Ed
15 years 2 months ago #21332
You can edit the file quantity of the view product and remove the <br/> tag at the bottom so that both are even. We'll do that too on our end in order to be consistent.
15 years 2 months ago #21336
Thanks!
