Related Products to Show under current product?
  • Thank you received: 5
15 years 9 months ago #2665
nicolas wrote:
I know JoomSEF built a plugin for HikaShop and we have the sef file for 404 directly in HikaShop so you shouldn't have problems using them.
In each product, you can add related products on the back end. Then, you can go to Display->Views and create a new module. Set it to be synchronized and to display related products on the product page. Then, go the configuration, under the tab display and for the option "modules on the product page" you can add that moduel you just created. Then, you should see it under the product page when you have products related to the main product displayed.
Hi nicolas ,
I seem to be having a small problem with following instructions.
if I goto display > views (there is no button indicating 'New' module)
thinking cognitively I went to Display Modules , which indeed I can add a new module.
Secondly becasue of the vast array of options inside the add module dialog box I looked around for the synchronized section which I also could not find.
what am I doing wrong here? Do you have a Tutorial somewhere for this kind of thing.
Cheers
:blink:
15 years 9 months ago #2666
ok it would seem that I overlooked the "Synchronize with currently
displayed item when possible
" which is indeed in the Display > Modules > New Module Dialog Box.
just working through the rest of the instructions now.
Last edit: 15 years 9 months ago by reace.
15 years 9 months ago #2670
ok next minor problem , the related products module only seems to work if I tell it to publish on all pages , which I am curious about because 'a' I do-not wish to publish it on all pages & 'b' selecting only selected pages does not work.
it would only seem logical to publish this module on pages that have 'products' inside of them , however it would be advantageous to be able to display various products on other pages as well.
I can only assume that their are some pages missing from the 'Menu Assignment' Module in the 'Module Manager'.
as this would explain why 'All Menus' Works but 'Select Menu Item(s) from the List' does not , even if all menu's are selected.
couple of other things worth noting about the related products module setup;
When following your instructions above it does not actually show that the module is in use beside the : 'Modules under the product page' [button].
  • Thank you received: 14201
15 years 9 months ago #2688
Sorry, I indeed wanted you to go to Display->Content modules :p
You found the synchronize option , good :)
You want to set the module on all the pages but keep it unpublished and then add it to the "Modules under the product page" option.
That way, joomla won't display the module because it is unpublished. However, when building the product page, hikashop will get the module regardless of the published option.
For the fact that you don't see the module name next to the option once you add the module: that's indeed the case. But if you click on the select button, you should see which one is selected and which one isn't.
The following user(s) said Thank You: max.mandias
15 years 7 months ago #5194
I created a new content module entitled Related Products, left it unpublished, synchronized it with current product, set it to show under the product, set two products related to each other in my products, but nothing shows! Please help.
15 years 7 months ago #5195
Which version of HikaShop are you using ?
Could you post the URL of the product page where you have related product ?
Could you also post a screenshot of your related module configuration ?
15 years 7 months ago #5196
I am using the Starter version. The first three books listed under the Books (Top menu) are related items and I would like them to show on each of the respective pages.
Here is the url:
www.urbansitedesigns.com/books/sex-and-the-bible
15 years 7 months ago #5198
Here is the screenshot.
15 years 7 months ago #5210
The options sound ok.
Could you make sure that your products are published and that your module is published in the option "modules under the product page".
15 years 7 months ago #5212
That is what I did not do. It works now! However, why are all the products displaying and not just the ones I stated where related?
15 years 7 months ago #5214
Also can I display just the images of the related products and the "add to cart" and not the descriptions?
Thank you so much for your help!!!!!!!
15 years 7 months ago #5216
Mmm. I think that the related option isn't taken into account because you link directly your products from a joomla menu and the product id isn't directly in the URL but in the menu options.
Could try to edit the file components/com_hikashop/views/product/view.html.php and add the line:
JRequest::setVar('product_id',$product_id);
just after the line:
$product_id = $category_params->get('product_id');
And then try again ?
In your module options, you set the item layout to "image and description". If you just want the images, you should set it to "image"
15 years 7 months ago #5218
I would never have figured this out without your help!! Thank you!!!!!!!!! Awesome support for a free product. Must upgrade.
  • Thank you received: 18
15 years 7 months ago #6134
A bug in 1.4.4 maybe??
I have Essentials and just loaded version 1.4.4.
When I click on System > Configuration > Display and click the "Modules under the product page" Select button it opens a lightbox with my Hikashop content modules listed. When I click on a module name it opens a new window and instance of the Joomla administration backend. Then no matter what I do the selected module is not saved in System > Configuration > Display.
15 years 7 months ago #6145
You need to set the published option to yes in the popup of that option. Clicking on the module will just direct you to the module's joomla options.
15 years 6 months ago #9254
Sorry to butt in on this thread but I'm having similar issues.
Can you clarify which of the "Modules under the product page" option you are referring to - General Display Options, Modules Main Default Options or both.
15 years 6 months ago #9256
It's the one under "General Display Options"
15 years 6 months ago #9261
OK thanks.
I want only two related products to appear below all print products, they are two kinds of framing services. At present this is what I have but the two related products show up on product pages where I have NOT added related products in the product edit page.
This includes the two frame service products too, which is obviously wrong to display the same product as a related product.
Therefore something is amiss somewhere. Here's some more screen shots of the settings for you:
15 years 6 months ago #9262
Module settings:
15 years 6 months ago #9263
Config --> Display settings:
The "modules main default options" have no "module display..." selected.
Last edit: 15 years 6 months ago by agrfoto.
Time to create page: 0.118 seconds
