How to create content tabs within products
14 years 8 months ago #33127
My client wants to have 2 to 3 tabs per product so they can put large amounts of content in for each product but not have the landing page too busy.
Here is an example of what they want to do - see the tabs that are labled "Description | Additional Images (1) | Related Products (3)"
http://www.skandivis.co.uk/aristocat-cushion
But they would like them labeled "Description | Specifications | Terms and Conditions"
Is this possible with Hikashop? If so how can it be done so that the client can determine how tabs that they want and edit/enter the content on each tab?
Cheers
shifty
  • Thank you received: 14210
14 years 8 months ago #33148
Yes, you can do that using for example the tabber plugin : extensions.joomla.org/extensions/news-di...contents-panel/14493
The following user(s) said Thank You: Bugger101
  • Hikashop Essential
14 years 2 months ago #55387
I am using Tabs & Sliders ( extensions.joomla.org/extensions/news-di...s/articles-tabs/1046 ) and it works fine for items without variants ( www.seekwithinyou.com/component/hikashop...t/cid-31#description ). When I use this for items with variants it is not functioning correctly ( www.seekwithinyou.com/books-guided-medit...-spirit-health-ebook ). When you first access the page, you can read from all of the tabs and then when you click on the variants, the tabs do not work.
I also tried this with the tabber plugin and the variants still do not work. Please help! Thanks!
"The doctor of the future will give no medicine, but will interest his patients in the care of the human frame, in diet, and in the cause and prevention of disease." Thomas Edison
Meditation for Health
Last edit: 14 years 2 months ago by jackpotwinner.
14 years 2 months ago #55452
You should follow the recommendations of that thread:
www.hikashop.com/en/forum/3-bug-report/1...eristic-changed.html
13 years 8 months ago #83675
hi,
any other tabs plugin recommended for joomla1.5 and work fine with hikashop?
thanks
13 years 8 months ago #84067
Tabber was compatible with Joomla 1.5. It seems that they removed the compatibility flag. You would have to try the others. We had always recommended Tabber so far.
