no stock for unlimited stock products
  • Thank you received: 6
14 years 7 months ago #37003
I have some products which i dont keep any in stock, i order them from a supplier upon getting an order on my shop. At the moment I have stock set to 0 for these items, however in the shop frontend on the product it displays no stock.
Is the best way for me to do this is to just put an 'imaginary' figure of 99999? or is there a setting for unlimited?
thanks
  • Thank you received: 4078
14 years 7 months ago #37010
If you set the stock to "-1" it will be transformed to "unlimited".
The following user(s) said Thank You: woonydanny
14 years 7 months ago #37145
When i create a new product by default it shows 'Unlimited'. Is that the same as writing '-1'?
can i write either in the quantity field?
14 years 7 months ago #37201
You can write "unlimited" or "-1", it is the same thing.
But it is easier and faster to write "-1" !
