Some products keep blank?
14 years 7 months ago #38054
I have a strange problem.. Some items are blank? only the image and price is showing, and the product description is not showing.. also the charesteristic dropdown is not there? :(
With an other product only one dropdown is shown? :(
Can you see what is happening here? If i check the backend, everything is there!
For Example this item: www.wildwestern.nl/index.php?option=com_...4&category_pathway=0
And a screenshot of its productpage backend:
The other one, with only one dropdown is thisone:
It said: 'no value found' instead of the dropbox...
Last edit: 14 years 7 months ago by Biird.
  • Thank you received: 14214
14 years 7 months ago #38111
It's probably because the variants/characteristics data is out of sync. Please try to follow the instructions here to regenerate the variants/characteristics data:
www.hikashop.com/en/support/documentatio...html#characteristics
14 years 7 months ago #38745
its a weird solution.. but it works.. thanks..
