Help with product display
14 years 6 months ago #39983
Hi Nicola,
I've got a ebook category that has sub-categories
I've got a menu that links to the ebook category, which displays the sub-categories
When you click on one of the sub-categories, the products aren't displayed as I want like for all other product displays I've got.
For the other products, I created a menu link so I was able to get them the way I wanted.
I don't know how to do the same for these sub-category products because I haven't got a menu link
I've attached the screenshots
14 years 6 months ago #40087
bump
14 years 6 months ago #40090
I've added menu links and they display correctly when you click on those links.
but from the category listing, when you click on the links of the sub-categories, the products still display as per screenshot
In the configuration > Display, default parameter for DIV is image and title
thanks
  • Thank you received: 14214
14 years 6 months ago #40101
The configuration Display options are only for NEW menus and modules.
For existing menus and modules, you should go in the menu Display->Content menus/modules where you will find similar options but specifically for your menu/module.
Also, when your menu is a category listing, in its hikashop options, you will have a link to the options of the products listing.
14 years 6 months ago #40104
Nicola,
the display through the menu works fine.
if you go from the menu and click on a sub-category, it works ok.
if you click on the menu to display the sub-categories and then click on a sub-category from the web page, then it doesn't display right
have a look:
www.horsewhispers.com.au/jupgrade/index.php/products/ebooks
14 years 6 months ago #40141
I fixed it
I deleted the category listing and recreated a new one, Now it displays fine
Time to create page: 0.404 seconds
