Re: change per unit into per set, per length, per reel
14 years 3 months ago #51416
I was about to post a very similar question. I want to show price for some products as "each" (or no text) and others by the metre, etc. I've used Translate override to display "per metre" instead of "each", but I can't find a way to disable that for other products. Ideally it would be possible to set a conditional translate according to, at least, category but preferably to product also.
Last edit: 14 years 3 months ago by sewsew. Reason: typo
14 years 3 months ago #51762
Hi sewsew,
I think that this answer can be the solution for your problem:
http://www.hikashop.com/fr/forum/4-how-to/51395-change-per-unit-into-per-set-per-length-per-reel.html#51475
