Issue with product position
14 years 3 months ago #52000
I create a perfect liquid template, with three columns. The issue is that when I have a module in the left side and I place the product listing, a empty space appear like this photo.
I don't know why this happens but I need to eliminate that space.
Please help
14 years 3 months ago #52001
Can you give us a link to your website ?
14 years 3 months ago #52103
www.chefencasa.tk please let me know if you find the answer
  • Thank you received: 14212
14 years 3 months ago #52187
That's a CSS issue coming from the way your template is done.
You will have to edit either the CSS of your template via the joomla template manager, or the front end CSS file of HikaShop via the Display tab of the configuration and add that CSS:
.hikashop_subcategories, .hikashop_products {
clear: none !important;
Don't forget to refresh your browser's cache after that.
14 years 3 months ago #52257
Hi nicolas
That almost work but still have some issues take a look
chefencasa.comoj.com/index.php/se/product/cid-1
hope you can help me
14 years 3 months ago #52300
For that page, you can use that CSS:
.hikashop_product_page .clear_both{
14 years 3 months ago #52347
No change in the page, have any ideas why?
14 years 3 months ago #52350
Refresh your browser's cache.
14 years 3 months ago #52355
Clear the cache and reload and nothing happen.
14 years 3 months ago #52413
I can see that page correctly now on my end.
It has to come from your browser's cache.
14 years 3 months ago #52442
No luck refresh cache used another pc still see the same.
14 years 3 months ago #52498
Now I see the problem again...
It seems that you changed something again.
I can see that you are now using the default front end CSS file instead of the custom front end CSS file. Please change the selection in the Display tab of the configuration and save the configuration.
Time to create page: 0.230 seconds
