Moving product parts around
14 years 3 months ago #54039
In the CSS, would anyone know how to swop these two around?
.hikashop_product_right_part{
.hikashop_product_bottom_part{
14 years 3 months ago #54054
I think that you'll just have to :
- Go to "Hikashop->Display->Views"
- Edit the "Schow_default" file of the product view of the template that you are using in the front-end
- Switch the code of the "<div id="hikashop_product_right_part" class="hikashop_product_right_part">" div whith the code of the "<div id="hikashop_product_bottom_part" class="hikashop_product_bottom_part">" div
Hope this will help you a little.
The following user(s) said Thank You: ryand500
14 years 2 months ago #54482
Thanks that helped a lot but now i wish to move my add to cart button and price below the product image
This is what it looks like now
and this is what I would like it to look like
Got any ideas :)
14 years 2 months ago #54483
Yes,
- delete the code :
<div id="hikashop_product_quantity_main" class="hikashop_product_quantity_main">
    <?php
    $this->row = & $this->element;
    $this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form\')){ return hikashopModifyQuantity(\'' . $this->row->product_id . '\',field,1' . $form . '); } else { return false; }';
    $this->setLayout('quantity');
    echo $this->loadTemplate();
  </div>
- add the code :
    <?php
    $form = ',\'hikashop_product_form\'';
  </div>
under the code
<?php
  $this->setLayout('show_block_img');
And it should works.
Time to create page: 0.337 seconds
