Check Out Work Flow
14 years 3 months ago #54074
Hi there
I am trying to sort out my checkout work flow and would like to use the advanced option. However when i click the advanced option to yes the old style workflow remains. Cache is off. Any one know of any ideas?
Many Thanks
Nick
14 years 2 months ago #54126
Any Ideas Guys? My log in feature is also not present on the front end, and i cant upload files via the form i have built.
I have a feeling all these could be a related problem.
Im running joomla 1.5.26 if that helps
Many Thanks
  • Thank you received: 14212
14 years 2 months ago #54132
Login feature => make sure that you still have the login view in your checkout workflow and that you're not logged in when testing.
can't upload => Maybe you files are too big for your upload limit of your PHP settings ?
No advanced edition of the checkout workflow => You're on 1.5 and the mootools upgrade plugin is not installed/published.
14 years 2 months ago #54137
Thank Nicolas
No problem about the checkout work flow i am looking to migrate to the latest once the site is finished. Maybe should have done this before but i have had the site while anyhow.
The login feature - has now appeared once i logged out of my site, only problem is the registration section is saying "Registration not allowed" although i have enabled it in the configuration do you know what could be the problem?
Cant Upload - Still cant upload, i have the size set to 8M tried to upload a 4M and will not work i get an 500 error message, have spoken with server provider but yet to get a reply. I had a problem uploading the Hikashop via the usual install on joomla and had to go through the install directory (after your much appreciated help). I think these two problems are linked some how.
Many Thanks
Nick
14 years 2 months ago #54223
The login feature - That's because in the options of the user manager of joomla (in the configuration of joomla for 1.5), you deactivated the user registration. Enable it and it will work.
Cant Upload - If you had a problem with the upload of the hikashop package which is only 1.5M, no wonder that it doesn't work for images... Your hosting company should be able to help you more than us sort out the problem, whether it's a php setting issue, or an access rights issue (joomla might not be allowed to write the uploaded files in your folders because of their permissions).
14 years 2 months ago #54399
Thanks Nicolas
So easy when you know how, registration working ok now.
I have referred the upload issue with my hosting provider who hopeflly can help, mangaged to upload a 56k png file but cant upload large jpegs. Getting there slowly
many thanks again
nick
