Point on products
14 years 2 months ago #56154
I want a points system applied in the shop. If a customer ordered a product, it automatically gets a number of points. Example, if he has earned 100 points with 10 products purchased, he may pick a free item in a particular category.
Is that possible in Hikashop?
Thanks for the responses.
  • Thank you received: 14211
14 years 2 months ago #56213
Yes, you can use our integration with AlphaUserPoints for that:
www.hikashop.com/en/support/documentatio...userpoints-form.html
The following user(s) said Thank You: fnuus
14 years 1 week ago #63368
I'am now looking for how i connect points on a product. But i cannot find it at all...
I can't find it in the manual either.
Fred
14 years 1 week ago #63535
You cannot add points directly to products.
You can add points to categories of products or with the currency to points rate option.
So for example if you set the category "fish" with 10 points, for each product of that category the customer will get 10 points.
