Custom products with images and uploadable logos
14 years 1 month ago #60380
Hi - just wondering if anyone has given any thoughts to the possibility of being able to customize a product with different colours and have the images change accordingly. I know this is possible with options (or at least I think it is) for a single colour but if I have a product with 4 different configurable colour areas such as a sports shirt where the collar can be one colour, the sleeves can be a different colour, the body a different colour and then some trim in a further colour. I'm thinking of something with 4 superimposed images that can be changed automatically as options are selected.
Another thing would be the ability to upload 1 or more image files that contain logos to be applied to the shirts etc.
Have lots of opportunity to put such a customisation into practice.
How would you do something similar?
  • Thank you received: 14211
14 years 1 month ago #60423
The only way to do that in HikaShop without any code modification would be to have characteristics on your product and then upload the combination image for each variant (combination of each values of the characteristics).
If you have lots of them that's clearly impractical.
A superimposed images system would definitely require customization to be done by a developer. So I would recommend that you find a joomla developer for that.
