Help with displaying product thumbnail in cart mod
14 years 2 weeks ago #62826
Hi all,
From searching the forum i understand that there is no option to add the product image into the cart module as standard. However if i override the product/cart.php file with some additional PHP and HTML this can be achieved.
I have attempted to do this by adding this code after line 139:
<td class="hikashop_cart_module_product_image hikashop_cart_value">
<div class="image">
   <?php if(!empty($row->images)){
      $image = reset($row->images);
      if(!$this->config->get('thumbnail')){
         echo '<img src="'.$this->image->uploadFolder_url.$image->file_path.'" alt="'.$image->file_name.'" id="hikashop_main_image" style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle" />';
      }else{
         $height = $this->config->get('thumbnail_y');  ?>
         <div class="hikashop_cart_product_image_thumb" >
            <?php echo $this->image->display($image->file_path,true,$image->file_name,'style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"'); ?>
         </div>
      <?php }
</div>
</td>
The image is not displaying, i presume some variables need assigning? could you give me some pointers on how to achieve this?
The link to the site is: www.rock-a-bye-rosie.com/
If you add something to the cart and then click the "My Shopping Bag" text on the top right of the window you will see the cart in a pop-up.
Thanks in Advance
Sean R.
14 years 2 weeks ago #62853
Hi reders,
The variable "$row->images" doesn't exist. The cart doesn't load any images.
You will need to edit the request in the view.html.php file to have the image path.
14 years 2 weeks ago #63028
Hi Thanks for your response.
I've been trying to edit the file /components/com_hikashop/views/product/view.html.php
However my PHP skills are not fantastic, i'm not really sure what code i need to add.
From looking at the checkout/view.html.php file i think i need to add:
function _getImagesName($type){
		$images_folder = HIKASHOP_MEDIA .'images'.DS.$type.DS;
		jimport('joomla.filesystem.folder');
		$files = JFolder::files($images_folder);
		$images = array();
		foreach($files as $file){
			$parts = explode('.',$file);
			array_pop($parts);
			$name = implode('.',$parts);
			$images[$name] = $file;
		$this->assignRef('images_'.$type,$images);
and
$show_image = $config->get('show_cart_image');
$this->params->set('show_cart_image',$show_image);
$currencyClass = hikashop_get('class.currency');
$this->assignRef('currencyHelper',$currencyClass);
$image = hikashop_get('helper.image');
$this->assignRef('image',$image);
within the function cart()
Is this correct or am i way off?
Thanks in advanced
Sean R.
  • Thank you received: 14211
14 years 1 week ago #63143
You're way off.
As Xavier said, you need to load the images of each product from the database. So you need to have a SQL query.
Something like that:
$db =& JFactory::getDBO();
$d->setQuery('SELECT * FROM '.hikashop_table('file').' WHERE file_ref_id='.$row->product_id);
$row->images = $db->loadObjectList();
