Change display options for products inside article
13 years 11 months ago #67222
Hi Guys.
I'm adding products to an article in my site using the plugin. How can I change the display options for the products to display in 3 columns (default is 1 column) and make the product thumbnail bigger???
13 years 11 months ago #67259
We set the default product thumbnail's size to 100x100 but you can change it through the file "'YourHikashop'\plugins\system\hikashopproductinsert\hikashopproductinsert_view.php" by changing the lines :
if(!empty($product->images)){
						$image =reset($product->images);
						echo $this->image->display(@$image->file_path,false,$this->escape(@$image->file_name), '' , '' , 100,  100);
by
						echo $this->image->display(@$image->file_path,false,$this->escape(@$image->file_name), '' , '' , YOURWIDTH,  YOURHEIGHT);
We planned to make it an option for next Hikashop releases :).
Last edit: 13 years 11 months ago by Mohamed Thelji.
