problems with images at checkout
13 years 10 months ago #71660
Hello!
when i go to checkout i see the following
for some reason thumbnails for some products are not generated.
though as you can see 100x100 images are loaded ok
it is because i generated them in acdsee and loaded manually to the server
how can i force hikashop to generate all required image thumbnails?
or make them load from 100x100 directory
thank you
13 years 10 months ago #71811
In HikaShop > Configuration > Files, you can set the size of the thumbnails.
And when you add an image to a product and then save the product, the thumbnails are automatically generated.
Time to create page: 0.190 seconds
