Cart Module additions - $ sign, refresh and clear
13 years 10 months ago #72192
Hi helpers out there!
I want my customers to be able to check their cart as they go. They therefore need to update the cart (on page that is separate to the checkout). They can change the quantity field but how do I get the "refresh" functionality there? At the moment if you press return you get taken to the checkout. I don't want that.
Also, I would like to show the $ sign. Format $ 0.00 AUD. I read the FAQ on this and it said to switch off the suppress the dollar sign extension but which extension?? I cannot find it.
Do you have a "clear cart" button that can be inserted on this module?
Sue
Last edit: 13 years 10 months ago by suebardak. Reason: Added another item and made title clearer
13 years 10 months ago #72305
To display the refresh button in the cart module, edit the view "product / cart" in HikaShop > Display > Views and paste the code:
										<div class="hikashop_cart_product_quantity_refresh">
											<a href="#" onclick="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); if (qty_field && qty_field.value != '<?php echo $row->cart_product_quantity; ?>'){<?php echo $input; ?> qty_field.form.submit(); } return false;" title="<?php echo JText::_('HIKA_REFRESH'); ?>">
												<img src="<?php echo HIKASHOP_IMAGES . 'refresh.png';?>" border="0" alt="<?php echo JText::_('HIKA_REFRESH'); ?>" />
											</a>
										</div>
Before:
										<input id="hikashop_cart_quantity_<?php echo $row->cart_product_id;?>" type="text" name="item[<?php echo $row->cart_product_id;?>][cart_product_quantity]" class="hikashop_product_quantity_field" value="<?php echo $row->cart_product_quantity; ?>" onchange="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); " />
Actually there is no "Clear cart" button, but you can add something like:
						<a href="<?php echo hikashop_completeLink('cart&task=newCart&cart_type=cart'.$Itemid); ?>">
							<span class="icon-32-add_cart" title="<?php echo JText::_('NEW_CART'); ?>">
							</span>
						</a>
In the previous view.
