Importing products -- struggling with images...
13 years 10 months ago #75734
Products load via CSV but no images...
CSV file has a column named images, containing:
media/com_hikashop/upload/Boardgames/Carcassonne-05-Abbey.jpg
Product is created, but when looking at the product there is no image. Look at it through the back end and the image file is listed as:
media/com hikashop/upload/Boardgames/Carcassonne-05-Abbey
There is no underscore in com_hikashop and there is no file extension on the image file.
I would really like to understand how to specify the file location properly. Can you use the full URL to the image? Is the relative file name relative to the public_html folder?
Many thanks for your help.
Ian P.
griffingrove.com
Ian P.
Griffin Grove Gaming
www.griffingrove.com.au
13 years 10 months ago #75850
In order to try and determine what HikaShop expects in the import file -- and why my images weren't appearing -- I deleted the image from one of my products and loaded another manually. Then I used phpmyadmin to check the results in the database.
The image file name used was Carcassonne-05-Abbey.jpg.
The file was loaded into the media/com_hikashop/upload folder -- as expected.
The *hikashop_file table had a new entry where file_name was NULL and file_path = carcassonne-05-abbey.jpg.
What surprised me here was that HikaShop had converted the image file name into lowercase.
I then moved the image file from the upload directory into upload/Boardgames -- and edited the file location. The image could not be located. Then I renamed the folder from Boardgames to boardgames -- and the image was now displayed.
So the solution here appears to be to ensure that all sub-folder and all image file names in the media/com_hikashop/upload must be lowercase. The import CSV file must then reflect this lowercase folder and file naming convention.
Ian P.
Ian P.
  • Thank you received: 14210
13 years 10 months ago #76023
On our end, we are able to import products with images regardless of the case of the file name and the image path will be ok.
Maybe it's something related to your web server configuration ?
Anyway, having everything in lowercase is indeed a solution for your case.
