Odd problem with category listing module
13 years 9 months ago #79992
I'm having a problem with the category listing module when set to show "all direct sub categories".
http://compusale.cloudaccess.net/computer-parts-sale.html
On the "Categories" module to the left. That module always have the "Motherboard" category opened up (showing it's sub categories such as "AMD (FM1)"). No matter which category I click on, once the page loads up, the "motherboard" category will be opened again.
For example when I click on the "Opteron" category ( a sub category of "CPU"), it goes to a page displaying Opteron CPUs BUT the Categories listing module will have the "Motherboards" category open up again (instead of having CPU open up)
Is there any way to make the correct category open up? i.e. when I'm in "Opteron", the "CPU" category will open up instead of "Motherboards" category?
If not, is there anyway to make no categories open up by default?
regards
Simon
Last edit: 13 years 9 months ago by simon2012.
13 years 9 months ago #80059
To edit this functionality, you have to edit the view "category / listing_list".
Here is some code which should unselect default category:
					?><script type="text/javascript">
						if (window.addEventListener)     { window.addEventListener('load', changeClass, false);  }
						else {  window.attachEvent('onload', changeClass);  }
						function changeClass()    {
							document.getElementById('<?php echo 'category_pane_'.$k; ?>').className="title pane-toggler";
					</script><?php
Add it just after: "echo $this->tabs->endPanel();"
The following user(s) said Thank You: simon2012
13 years 9 months ago #80126
Thanks for the reply Xavier.
I can't seem to get that code to work (not sure if I'm putting it in the correct place). Can you please copy and paste the entire "category / listing_list" here?
Also my client wants the selected category to open by default. i.e. when in a sub category of "CPU", the CPU category will open. Is this possible?
13 years 9 months ago #80185
Here is the entire file:
<?php
if(!empty($this->rows)){
	$pagination = $this->config->get('pagination','bottom');
	if(in_array($pagination,array('top','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value){ $this->pagination->form = '_top'; ?>
	<form action="<?php echo hikashop_currentURL();?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_top">
		<div class="hikashop_subcategories_pagination hikashop_subcategories_pagination_top">
		<?php echo $this->pagination->getListFooter($this->params->get('limit')); ?>
		<span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span>
		</div>
		<input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" />
		<input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" />
		<?php echo JHTML::_( 'form.token' ); ?>
	</form>
	<?php } ?>
	<div class="hikashop_subcategories">
	<?php
	$only_if_products = $this->params->get('only_if_products',0);
	switch($this->params->get('child_display_type')){
		case 'nochild':
		default:
				<ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>">
				<?php
					$width = (int)(100/$this->params->get('columns'));
					if(empty($width)){
						$width='';
					}else{
						$width='style="width:'.$width.'%;"';
					$app =& JFactory::getApplication();
					$found = '';
					if(JRequest::getString('option')==HIKASHOP_COMPONENT && in_array(JRequest::getString('ctrl','category'),array('category','product'))){
						$found = $app->getUserState(HIKASHOP_COMPONENT.'.last_category_selected');
						foreach($this->rows as $row){
							if(JRequest::getString('ctrl','category')=='product'&&JRequest::getString('task','listing')=='show'){
								$cid = JRequest::getInt('category_pathway',0);
							}else{
								$cid = JRequest::getInt('cid',0);
							if($cid == $row->category_id){
								$found=$row->category_id;
								$app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected',$row->category_id);
								break;
						if($only_if_products && $row->number_of_products<1) continue;
						$link = hikashop_completeLink('category&task=listing&cid='.$row->category_id.'&name='.$row->alias.$this->menu_id);
						$class = '';
						if($found == $row->category_id){
								$class=' current active';
						<li class="hikashop_category_list_item<?php echo $class; ?>" <?php echo $width; ?>>
							<a href="<?php echo $link; ?>" >
							<?php
								echo $row->category_name;
								if($this->params->get('number_of_products',0)){
									echo ' ('.$row->number_of_products.')';
							</a>
						</li>
						<?php
				</ul>
		<?php
			break;
		case 'allchildsexpand':
			<div id="category_panel_<?php echo $this->params->get('id');?>" class="pane-sliders">
			<?php
				foreach($this->rows as $k => $row){
					<div class="panel">
						<h3 class="jpane-toggler title" id="category_pane_<?php echo $k;?>" style="cursor:default;">
							<span>
								<a href="<?php echo $link;?>">
									<?php
								</a>
							</span>
						</h3>
						<div class="jpane-slider content">
							<ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>"><?php
							if(!empty($row->childs)){
								$found='';
									}else{
									foreach($row->childs as $child){
										if($cid == $child->category_id){
											$found=$child->category_id;
											$app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected',$child->category_id);
											break;
								$limit = $this->params->get('child_limit');
								$i = 0;
									if($only_if_products && $child->number_of_products<1) continue;
									if(!empty($limit) && $i >= $limit){
										break;
									$i++;
									$link = hikashop_completeLink('category&task=listing&cid='.$child->category_id.'&name='.$child->alias.$this->menu_id);
									$class = '';
									if($found==$child->category_id){
									<li class="hikashop_category_list_item<?php echo $class; ?>">
										<a href="<?php echo $link; ?>">
										<?php
											echo $child->category_name;
												echo ' ('.$child->number_of_products.')';
										</a>
									</li>
									<?php
							?></ul>
						</div>
					</div><?php
			?></div><?php
			break;
		case 'allchilds':
			jimport('joomla.html.pane');
			$found = -1;
			if(JRequest::getString('option')==HIKASHOP_COMPONENT && in_array(JRequest::getString('ctrl','category'),array('category','product')) && $cid = JRequest::getInt('cid',0)){
				$i=0;
						if($row->category_id==$cid){
							$found = $i;
							break;
								if($child->category_id==$cid){
									$found = $i;
									break 2;
						$i++;
					if($found>=0){
						$app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected',$found);
					}else{
						$found = (int)$app->getUserState(HIKASHOP_COMPONENT.'.last_category_selected');
			}else{
				$cid = 0;
			$this->tabs = hikashop_get('helper.sliders');
			$this->tabs->setOptions(array('startOffset'=>$found,'startTransition'=>0));
			echo $this->tabs->startPane( 'category_panel_'.$this->params->get('id'));
						$row->category_name.= ' ('.$row->number_of_products.')';
					if( !$this->module || $this->params->get('links_on_main_categories')){
						$row->category_name = '<a href="'.$link.'">'.$row->category_name.'</a>';
					echo $this->tabs->startPanel($row->category_name, 'category_pane_'.$k);
						?><ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>"><?php
								$class = '';
								if($cid==$child->category_id){
									<a class="hikashop_category_list_item_link" href="<?php echo $link; ?>">
									<?php
									</a>
								</li>
								<?php
						?></ul><?php
					</script><?php
			echo $this->tabs->endPane();
			break;
	</div>
	<?php if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value){ $this->pagination->form = '_bottom'; ?>
	<form action="<?php echo hikashop_currentURL();?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_bottom">
		<div class="hikashop_subcategories_pagination hikashop_subcategories_pagination_bottom">
		</div>
	</form>
	<?php }
I will try to see how to open by default as soon as possible.
13 years 9 months ago #80225
Thanks Xavier.
Regarding the codes, I inserted it but the category module is still not displaying properly. Can I send you the admin login (through contact us?) so you can make tests and adjustments directly?
I noticed in the category options, Hikashop already have an option called "Random items" (where a random category bounce up to top & open up). Maybe for future release we can have another option there that allows the active category to bounce up & open?
  • Thank you received: 14210
13 years 9 months ago #80521
I think that you should try instead to simply change the line:
$this->tabs->setOptions(array('startTransition'=>0));
in that file.
And please make sure that you're editing it for your frontend template and not another one, otherwise, you won't see any change.
13 years 9 months ago #80612
Hi Nicolas
Can you please have a look in my back-end administrator? (did you receive the login I sent via "contact us"?). I have tried both suggestions but still cannot get it to work.
13 years 9 months ago #80783
Is there any other solutions? I don't know if I can continue using Hikashop if this problem cannot be solved.
13 years 9 months ago #81037
I looked at the problem on your website regarding the fact that the proper category didn't expand but couldn't find why that could have happened since the selection of the category in PHP was the correct one.
And you said in your first message that having no category open would be fine too.
So, the code change I gave you was to do that.
I checked your website and that's what it is actually doing.
No category is opened when a page is displayed.
So my suggestion is ok, as far as I can see.
13 years 9 months ago #81142
Thanks Nicolas, that code worked (the changes did not come in effect until the next day, cookies?).
The menu is satisfactory in it's current state but an expanding one (with correct category) would be best. Is this possible?
13 years 9 months ago #81387
That's how it should be actually by default.
As I said in my last post, the data sent by HikaShop to the accordion library of joomla is correct on your website. I debugged that myself. So I don't see why it doesn't work on your website and don't have a solution for you.
13 years 8 months ago #81872
The problem is also present on my other domain.
http://shoptest.cloudaccess.net/cat-menu/category/18-sub-4.html
  • Thank you received: 4077
13 years 8 months ago #82027
I have fixed the problem in your website and I have made a fix in HikaShop which would be include in the next package.
If you want a generic fix, please edit the file administrator/com_hikashop/helpers/sliders.php
and replace
		if($this->mode == 'pane') {
			$this->tabs = JPane::getInstance('sliders', $options);
			$ret .= $this->tabs->startPane($name);
		} elseif($this->mode == 'sliders') {
			$ret .= JHtml::_('sliders.start', $name, $options);
		} else {
By this:
			if(!empty($this->options))
				$options = array_merge($options, $this->options);
		} else {
Regards and sorry for the inconvenient.
13 years 8 months ago #82204
Thanks Jerome :)
