Width problem when listing products via table
13 years 8 months ago #81877
I'm having a width problem on certain pages when listing products via table layout. As shown in attached images, the main content area seems to extend out of content box on certain pages. Is there any ways to fix this?
http://compusale.cloudaccess.net/computer-parts-sale/category/28-accessories-modding.html
http://compusale.cloudaccess.net/computer-parts-sale/category/93-ddr3-single-and-dual-channel-ram.html
http://compusale.cloudaccess.net/computer-parts-sale/category/92-ddr3-quad-channel-ram.html
thanks
Last edit: 13 years 8 months ago by simon2012.
13 years 8 months ago #81896
You can try to reduce the width of the td in CSS.
www.hikashop.com/fr/support/documentation/faq.html#css
13 years 8 months ago #81972
Hi Xavier
I'm not sure how to change the table via css editing. Can you please give me an example?
The product table only seems to extend out of the content box on some pages. It seems most logical to have a css that limit the maximum width of the table.
  • Thank you received: 25
13 years 8 months ago #81975
Hi Simon 2012,
I think you are trying to fit too much in the the limited space you have in the middle of your template.
The page with the biggest overhang is the one with the longest product names. The ones that fit are the ones with smaller product names.
Do you need them that long? Also remember that the product name will probably be used as the URL and these will be VERY long
If you want to keep the long product names, maybe reduce the padding around some of the elements (they are currently set at 20pxls but could be changes via a custom CSS to:
.hikashop_product_name_row {
padding: 0 2px;
.hikashop_product_price_row {
padding: 0 2px;
.hikashop_product_add_to_cart_row {
padding-left: 2px;
.hikashop_product_image_row {
padding: 2px;
Add something like that to your custom CSS (Configuration > Display)
To see these behaviors, a great tool if Firebug that your can get in Firefox to inspect (and display changes) a page's CSS.
Don't look at what is and ask 'why?'; look at what isn't and ask 'Why Not!'
The following user(s) said Thank You: simon2012
  • Thank you received: 403
13 years 8 months ago #82028
sambob said everything :)
It's just a CSS issue that you can fix by adding some css in Display>Configuration by editing the front end css file.
Using width property can also help you.
Do not hesitate to take a look at our FAQ for more information about css stuff :)
