Problems with my cart
13 years 8 months ago #82667
I have just set up a shop but the cart doesn't have any go to checkout button.
This means that I can add products to the cart but I can't go to the checkout.
How can I add a checkout button?
Another thing is it possible to check out without registering as a customer?
I don't want to have 1000 registered customers in the database so there must be a way to let customers just fill in their address and checkout with PayPal for example.
Greatful for any assistance with this.
13 years 8 months ago #82735
Do you have the latest HikaShop version ?
Can you check in the view "product / checkout" if there are a part to display the "proceed to checkout" button ?
It's possible to checkout without registering, many topic are already talking about that, I invite you to make a search.
13 years 8 months ago #82743
Yes I have the latest version HikaShop Starter 2.0.0 on Joomla 2.5.8.
I don't find this view the one I find is:
Under Global settings/Display Standard parameters for products there is no such option but I might be totally disoriented here.
Ok I will make a search for that.
  • Thank you received: 26
13 years 8 months ago #82744
I think a way that you may be able to do is that in your checkout process you don't require registration
http://gyazo.com/010e030aad18331969a41ab7f2ab9180.png?1355910854
go into system - configuration - checkout and then on the registration option try no registration.
That may work for you.
Just a note, i'm another user who just saw this and thought that it might help, if not i'm sorry.
Tom
I'm not an expert at this, if i post on your thread i'm doing so with the best of my knowledge and just trying to help :)
13 years 8 months ago #82746
Tom,
Thanks a lot for your suggestion.
It seems though that this solution is for the Essential version as it say in my backend.
BR
Micke
13 years 8 months ago #82748
LAMF wrote: Tom,
BR
Micke
Aww, well good luck with fixing this, and upgrading is really worth it too :)
13 years 8 months ago #82754
Thanks I will go for the essential version as there's so much incomplete stuff in the free version. :)
13 years 8 months ago #82847
Upgraded to the Essential version but no where I can find how to add the checkout button to the cart.
How can such an important thiing just disappear?
13 years 8 months ago #82973
Can you check in you cart module options if the option "Show proceed button in the cart" is enabled ?
Could you give us a backend access to your website ?
Last edit: 13 years 8 months ago by Xavier.
13 years 8 months ago #83052
Xavier wrote: Can you check in you cart module options if the option "Show proceed button in the cart" is enabled ?
Hi Xavier,
I sent you login details in a PM.
Thanks!
BR
Micke
13 years 8 months ago #83055
Xavier,
Got the solution in this thread regarding the check out button:
www.hikashop.com/en/forum/4-how-to/76913...or-product-view.html
But still need assistance to find where I can change layout for the product view.
I would like 5 or 6 columns for listing of the products not 3 as it is now and I haven't found where to change this either.
13 years 8 months ago #83081
To change the number of columns, you have to edit you menu/modules parameters, in HikaShop > Display > Content menu/module change the number of columns to 5 or 6, if it's a menu, change the parameters too in the associated module.
Time to create page: 0.100 seconds
