Help with Product Listing
13 years 8 months ago #82688
Hi there
I am in the process of creating my shop and created a few mock products following the guide. I created two category levels and then tried to assign products to the lower level categories.
That worked but my issue is that it appears all products are now all showing up as well as the top level categories when I follow the menu link I created.
I have attempted to try and figure it out myself and have had a couple of attempts but still can't seem to work it out.
I am sure it's something simple that I've overlooked but would appreciate if someone could highlight it for me
Thanks heaps :)
Last edit: 13 years 8 months ago by lapartera69.
  • Thank you received: 25
13 years 8 months ago #82692
Go to you Hikashop menu look for 'Sub elements filter' on the LHS; and select 'Direct Sub Elements'.
Don't look at what is and ask 'why?'; look at what isn't and ask 'Why Not!'
The following user(s) said Thank You: Xavier
13 years 8 months ago #82703
Thanks so much!!
It worked :). Knew it had to be something simple!!
Much appreciated
Time to create page: 0.228 seconds
