Add same Characteristics to all products
13 years 8 months ago #84317
Is there any way I can add characteristics to ALL the products in the database without having to edit each product?
I have imported from excel approx 3000 products (Aircraft Prints) which are organised into Categories and Sub Categories all are 24 inches and cost $70 each, that’s all good no problems.
I now need to have an option for each to allow for a 36 inch print costing $125.
What be the simplest way of achieving this, any help greatly appreciated.
Last edit: 13 years 8 months ago by d0g.
13 years 8 months ago #84488
There is not really a way to do that, but the easiest will be to export your products in a csv file, edit this csv to add the variants, then import it again in HikaShop.
Here is some documentation about export/import:
www.hikashop.com/fr/support/documentatio...hikashop-import.html
13 years 8 months ago #84494
Thanks Xavier
I’ll do that, I just thought someone may have known away using some MySQL and phpMyAdmin.
Time to create page: 0.042 seconds
