Help with Magic Quotes/backslash issue!
13 years 8 months ago #84556
Hi all,
Today I modified the language file in an attempt to remove 'each' after the product price, only to realise that I had magic quotes turned 'ON'. I have since gone about turning them off via the tutorial which worked fine.
However, I still have backslashes throughout the front and back ends even after I modified the language file back to what it was ie. without the slashes. I am lost as to how I go about eliminating all the backslashes throughout my site.
I am hoping that someone can help me out, hopefully with a simple fix.
Thanks so much in advance :)
13 years 8 months ago #84662
Update! - Managed to solve the issue myself, something simple as always :)
13 years 7 months ago #88234
can you explain, HOW did you manage this?
13 years 7 months ago #88247
OK,
I found the solution by myself.
There is a override-file in joomla-directory/language/overrides named language&COUNTRY-code.override.ini. This file must be deleted/renamed.
The the problem with the magic quotes/backslashes is solved.
greez
jLo
Last edit: 13 years 7 months ago by jLo.
