Changing products displayed in content module
13 years 7 months ago #86258
Hi Folks,
Trying to find my way around Hika (v 2.0) I have created a content module which is in the front page of the site, showing 6 products, how do I change what products are displayed in this module?
Thanks for any help.
  • Thank you received: 4077
13 years 7 months ago #86268
You can modify the options of the hikashop module in the HikaShop backend : "Display > Content module".
13 years 7 months ago #86276
Thank for that, can I only change "Recently viewed" options? Is it possible to select the products?
13 years 7 months ago #86391
You can change the options for every modules, you can't select the products directly but you can select a category.
So if you create a new category, then add this category to the wanted products and choose this category in the module options, you will have the desired products displayed.
