Remove "Click for more details" from Products
13 years 5 months ago #94691
Hi There,
Since the links on the products take you through to the products page, I was wondering how you were able to remove the text "Click for more details" from the products, since this text is redundant.
www.barmanager.co.uk/Bob/index.php/furniture
Kind Regards,
Matthew
  • Thank you received: 14210
13 years 5 months ago #94920
That's funny you ask since there is no such link by default in HikaShop.
So it was either added by you or by your template.
You should edit the file listing_img_title of the product view via the menu Display->Views and remove the link that was added there.
